the driver crashed (line 867) - no idea whats wrong
you can open an issue at Issues · tbsdtv/linux_media · GitHub or maybe crazycat can help
Good news from my side - TBS5520SE is working on my RPi 2/3 and LE 9 Release.
I have not not tried DVB-T tuner, DVB-S2 is working - but ONLY with external power supply - on the red USB
[ 2.434877] usb 1-1.4: New USB device found, idVendor=734c, idProduct=5521, bcdDevice= 0.01
[ 2.434897] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.434909] usb 1-1.4: Product: TBS 5521
[ 2.434920] usb 1-1.4: Manufacturer: TBS-Tech
[ 11.726565] Latest git patches (needed if you report a bug to [email protected]
[ 11.726565] b9ac0e830b87e363d357353ab54ae9f892bbd821 si2183: i2x_mutex in base.
[ 11.735432] dvb-usb: found a 'TBS 5520se USB2.0' in cold state, will try to load a firmware
[ 11.778694] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5521.fw'
[ 11.778722] tbs5520se: start downloading TBS5520se firmware
[ 11.920932] dvb-usb: found a 'TBS 5520se USB2.0' in warm state.
[ 11.921690] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 11.929158] dvbdev: DVB: registering new adapter (TBS 5520se USB2.0)
[ 11.929199] usb 1-1.4: media controller created
[ 12.084823] dvb-usb: MAC address: 00:22:xx:xx:xx:xx
[ 12.088469] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
[ 12.125591] i2c i2c-3: Added multiplexed i2c bus 4
[ 12.125618] si2183 3-0067: Silicon Labs Si2183 successfully attached
[ 12.148039] i2c i2c-4: av201x: Airoha Technology AV201x successfully attached
[ 12.170440] si2157 4-0061: Silicon Labs Si2147/2148/2157/2158 successfully attached
[ 12.222853] usb 1-1.4: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2183)...
[ 12.222904] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2183' registered.
[ 12.223383] usb 1-1.4: DVB: registering adapter 0 frontend 1 (Silicon Labs Si2183)...
[ 12.223425] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2183' registered.
[ 12.230229] dvb-usb: TBS 5520se USB2.0 successfully initialized and connected.
[ 12.230624] usbcore: registered new interface driver tbs5520se
[ 29.081567] si2183 3-0067: found a 'Silicon Labs Si2183-B60'
[ 29.123819] si2183 3-0067: downloading firmware from file 'dvb-demod-si2183-b60-01.fw'
[ 29.792597] si2183 3-0067: firmware version: 6.0.13
