Still does not work.
I will go back to previous working version and wait.
LibreELEC 8.x images for additional dvb drivers
CvH -
April 17, 2016 at 7:29 PM -
Hi CvH,
Didn't load kodi for me. On Screen Messages :
Failed to start Xorg server
Dependency failed for Fluxbox window managerdmesg : SJKO
Nvidia GT218
Cheers,
Neil
- Official Post
Did not work.oh sorry, I forgot to remove a comment string xD
pls try LibreELEC-Generic.x86_64-7.90.009-testimage-for-not-working-tbs-0.3.img.gz (dmesg welcome) !
tx for your help !
Didn't load kodi for me. On Screen Messages :Failed to start Xorg server
that is the nvidia driver, we have to wait till the "new" one is released (should be this week)
current versions to test:
Generic: LE 7.90.009 TBS image 0.3 -
Hi cvh, I installed your 7.90.009 - 0.2 for rpi.
I'm stucked on "Add-on migration in progress" from one hour now, but the dots are flashing. It's normal that this progress requires all this time? Advice? Shutdown and reboot? -
- Official Post
I'm stucked on "Add-on migration in progress"that is normal, takes ~5min, if not work reboot
No luck. dmesg YIGS
- Official Post
No luck.sorry can't work, this kind of build is broken for now
CvH, do you mean build for tbs5922se or more general build broken? Is it worth trying for T230?
Ok, t230c continue ro works after the upgrade
- Official Post
yesThere are 2 ways to build the drivers
- first one is to patch the kernel to directly support the drivers (what we are trying) <- the much better way
- second one is to build it over media_build and replace the current kernel drivers completely with other drivers - this fails at the moment due the build changes at LE (have to investigate how to fix this)
Ok, t230c continue ro works after the upgradetx, great
(at least something is working like desired ;D) -
Generic: LE 7.90.009 TBS image 0.3Doesn't work
KNDK
Could we go another way? You build in-kernel drivers with only one patch applied: dvb-usb-cxusb: Geniatech T230 - resync TS FIFO after lock - Patchwork
Should be anougth for T230 proper work. I'll test then. This way we narrow down problem -
Need three patches for t230c support
t230c -
How Can I see the signal strenght and snr value in kodi (with O Key)?
I Can see it in Status from tvheadend, but not in Krypton. -
- Official Post
Need three patches for t230c supportyes this was already included (saw it too late at 0.1 and 0.2, 0.3 should have it)
Anyway, to patch the TBS drivers in looks like not working, to replace the whole stack isn't working either so "from my side" I would call it completely broken. Looks like media_build glues the broken things together that it works (I thought TBS is trying to upstream their stuff??).So for now a working Version (pre 010) and the drivers installed via media_build (this should work) - NVIDIA also fixed in this version
Generic Generic 7.90.009-TBS-0.4at this version is no T230C support !
Generic Generic 7.90.009-TBS-0.4No, it doesn't work either for T230: JXdK
CvH, could you please build with just plain-kernel drivers(no TBS, media_build stuff, etc.) and apply only mentioned patches on top, so I could test if it is the kernel regression or not with T230? -
- Official Post
plain LE with 4.9 ? -
