Problems finding IR hardware
  • I am running Libreelec off an SD card on an AMLOGIC S905X - Branded as MAG410.
    I have great performance and CEC works well but I'd like to use the factory remote specifically because of poweroff-poweron.
    The problem is even using the android remote.conf the remote buttons don't work. I believe this may have something to do with the IR receiver not being detected.
    If I run from ssh I get the following error:
    1. # ir-keytable
    2. /sys/class/rc/: No such file or directory
    Any idea how I can debug this?
  • what version of Libreelec are you using?
    for earlier versions, up to 8.2. something or other remote.conf repository
    NUC with LibreELEC Controlled by Logitech 350 / Beelink MiniMXIII S905 2G/16G 1000M Lan CoreELEC from NAND
    H96 Pro (S912) CoreELEC 8.95.6 Controlled by Harmony 650 (configured as Mecool KIII Pro)
    Mecool M8S Pro L running Android, Netflix NOT working
    Nvidia Shield Running Plex Android Kodi :)
  • I'm using 8.2.4.2.
    I tried following the forum post to create a remote.conf from scratch using debug option and reading dmesg, but no button presses are being captured.
    The remote works well using the stock android though.
  • Let's start from scratch.
    You want to use the remote as you want the function of power on/power off. I'm not an expert but I am not too sure these boxes can be powered on/off via remote. Normally a power recycle is needed.
    To assist: Please provide a full debug log as explained in my signature and also the output of dmesg | paste
    Forget about power on/power off. I just want to be able to use the IR remote.
    Here are the logs:
    http://ix.io/1jni - kodi.log
    http://ix.io/1jnj - dmesg output
  • Remotes are a PITA - there are so many variants with each having their own protocols, that is almost impossible to support.
    This might help IR. Also others have reported success with FLIRC. I personally gave in and just use a KB.
  • Hello! I need help. I have an Android box. I launch LE on a pendrive, but remote control does not work. I saved the remote.conf from android to the Le Config directory, but nothing went wrong. Whatever you press on the remote control, it does not look like a box led.
    How did you get on when you read the posts just above this one?
