Is there anyway to set the default rom directory to another source? I share a romset between batocera linux, and recalbox and would like to also use it with this librelec release. Could it possibly be added to the same tool/addon thats used to select the audio output device?
5schatten -
June 16, 2018 at 1:47 PM -
Closed -
Thread is marked as Resolved.
es_systems.cfg
es_systems.cfg
wouldnt you need to do it for every rom directory 1 by 1 in that case?
I would nothing! that´s your Roms and that´s Your Idea. I only say witch file you can edit to have what you want.
Look and you will understand. If not, it isn´t the right time to do that!
Before all of that you need to mount a network share! This is your first step to do all of what you want
Go bust a nut dude, I'm well aware of everything you've typed. Just haven't been using this os since janurary and was wondering if any progress has been made in that category.
anyway, another question for you're incel, miserable, ass! has this issue been fixed with psxbeetle?
Can you try this build with Displayport? Index of /testing/nvidia-430.26/
Can you check if your controller works again?
Thnx but i can’t download the file.
It’s forbidden. 403 forbidden
fixed -> file permissions where screwed for whatever reasons
Just tested and i can confirm that my controller is working again.
Thnks!
About the Chrome tearing problem Intel users should be able to fix it by creating a xorg.conf in configfiles root dir with the following content:
CodeSection "Device" Identifier "Device0" Driver "intel" VendorName "INTEL Corporation" Option "TripleBuffer" "true" Option "TearFree" "true" EndSection
Works for so far.
Works for so far.
Sorry but this isn't working for me.
What logs do you need to see what's is going wrong?
It either works or works not. But ofc you have to reboot after you've created the file.
I've uploaded testbuilds for Generic & RPi to Index of /testing/
Both are based on latest master with a huge load of updated packages packages: mega bump by MilhouseVH · Pull Request #3537 · LibreELEC/LibreELEC.tv · GitHub & many libretro cores & standalone emulators have been bumped too so feel free to test and report if something is broken. Both should boot fine btw. so don't worry about that.
why the joystick doesn't work ?
the system does not see it, does not respond to pressing
Which branch are you currently basing on? libreelec-9.2?
Updated the Generic version on htpc1 :
Kodi runs fine, tested some h264/265 and xvid files, using the Aeon MQ8 (2.9.0) skin
Mame tested some roms, works fine
Gamecube tested some games, works but no audio (config using pulse(all working emulators use pulse))
Amiga tested some games, works fine
Dreamcast not working,
3DS some games tested, works fine
PSP portable tested 1 game, works fine
PSP1 tested 1 game, works fine
PSP2 (dl new docker file) , stop running and a white screen.
(from log)
Plugins shutdown successfully.
Path: /root/.config/PCSX2/bios/ps2-0230e-20080220.bin
(p) Configured BIOS file does not exist, or has a file size of zero.(thread:EE Core)
This didn't work for me on a Chromebox with 2955u integrated Intel GPU. In fact the tearing is worse when this xorg.conf file is added and I reboot, occurring throughout the screen as opposed to in the top 30ish% without it.
I was lucky, at the first time it didn’t work for me on my nuc7i5bnh.
After i updated to the latest testbuild it was working😁
