Got a question as I am a total Noob with LE so far, my Minix X8 Plus I had installed "X8-X8H.arm-9.0-devel-20190202105130-8798984" Final version and using internal memory for data. Thanks to kszaq's "howTo"
That all works great. Today I decided to update it to "X8-X8H.arm-9.1-devel-20190221083437-627c12a" so I copied the .tar file to .Updates with FTP and rebooted.
It updated fine, but I noticed that Network switch = off, so turned it back on but after shutdown or reboot it toggles it back off!
So I just stuck 18.0 in the Update Folder and rolled back to that.
Dont get me wrong the 18.1 version worked great just the Network Switch got me spooked ....
Did I Update the wrong way where I am using internal memory or is there a glitch in the 18.1 version?
