The HDMI crashes and I have to completely power cycle the minix in order for the display to come back. Otherwise, it stays on the same frozen screen, even when rebooting via ssh.
This happens when I stop a video, pause, fast forward, or rewind. Also, I set the audio to snapserver pulseaudio. It all works fine as long as I don't do the above. Any ideas?
i got this with a old plasma tv hd-ready, not supporting 24hz/24p.
see below
you need a tv supporting 24hz/24p and you need to set (in Kodi) "adjust refresh rate" and have to define a "whitelist"
select Amlogic M8-analog even if you're using the hdmi (it helps to fix no audio with some files played by the avr)
gotcha ![]()
