Spotify Connect Web
    first thanks for that addon but i have a problem.
    I installed the addon from the repo after that i put my spotify_appkey.key in the folder.
    But when i try to configure ALSA with the wizzard only the message "Could not find a playback device" pop up.
    -- Logs begin at Sun 2016-11-20 12:10:08 CET, end at Tue 2016-11-29 19:02:24 CET
    Nov 20 12:10:11 LibreELEC systemd[1]: Started spotify-connect-web.
    Nov 20 12:10:11 LibreELEC sh[433]: Playback device not set
    I hope u can help me :(
  • Hm... weird
    Try this command at the console and then try again:
    dtparam audio=on
    If that does not work, try adding the following line to config.txt, reboot and retry:
    dtparam=audio=on
    If that does not work, try vanilla LE
    dtparam=audio=on fixed my problem thank you!
    i got now 2 devices, HDMI and audio jack or?
  • Check its content, name and location. According to your logs and scw github issues, it could be that app key is invalid.
    Thanks.
    But I can't find in the "28 issues" any problems like this, on github.
    Edit:
    I have 4 options in my email from spotify.
    HEX/BASE16 APPKEY
    BASE64 APPKEY
    BINARY APPKEY
    C APPKEY
    Under these options are a lot of "words" :D Maybe i can do something with this stuff? :D
    Well, and the spotify_app.key from spotify, as well.
    Edited once, last by Danmann (November 29, 2016 at 8:00 PM).
  • Thanks.
    Edit:
    HEX/BASE16 APPKEY
    BASE64 APPKEY
    BINARY APPKEY
    C APPKEY
    See post #147 and upwards. Can't test myself (no key e-mail). Maybe see with effe.rnr how he got his key working. If you manage, please be so kind to document in this thread, for other users. Tia
    Sounds familiar: use ALSA and PCM, select the desired output HDMI or jack
  • Hi, I received the email with the .key file in attached, but it doesn't work. I can't see the rpi3 libreelec 7.0.2 from the Spotify app.
    I can't check the .Key content because the text inside is "compiled". I suppose that it is the binary file.
    The previous page
    Libspotify Application Keys - Spotify Developer
    used to download the personal Keys does't work anymore.
    So the email is the only source.
    Another question, It's not clear (at least for me) how to check the 4000 port.
    I type in my browser (in the same LAN of rpi3) 192.268.1.86:4000 (.86 is my rpi3) but the page is blank (ERR_CONNECTION_REFUSED)
    Any help, please?
    The previous page
    Any help, please?
    According to post #147 and previous, some info from the key email must be processed to generate the app key. I can't test this, because I have no key email. If the key is not valid, the service (and its web ui) will fail.
  • Hi, solved.
    It's not an issue of base64 decode. We can use directly the .Key file attached in the email. In my case the issue is that I didn't use the alsa configurazione wizard.
    After doing that, all works fine.
    Yes I know... I'm a dork :)
    I really love this addon. Thank for all :*
  • Thanks.
    Edit:
    HEX/BASE16 APPKEY
    BASE64 APPKEY
    BINARY APPKEY
    C APPKEY
    you can generate your app key by doing the following steps:
    1. open Base64 Online - base64 decode and encode
    2. paste your key in the into the field
    3. select decode and "to binary file"
    4. save the binary file. With this file it should work
  • Another question, It's not clear (at least for me) how to check the 4000 port.
    For information : With SSH in LibreElec, you can type :
    netstat -taupen | grep 4000
    If the service is working, you should see something like :
    tcp        0      0 0.0.0.0:4000            0.0.0.0:*               LISTEN      593/spotify-connect
    If nothing appears, something is wrong.
  • you can generate your app key by doing the following steps:
    Thank you,
    but it doesn't work for me.
    I think my key isn't made for any acc. Just a "test-key" maybe.
    Do you guys see you're acc name at this place? ....Established under name 'TestConnect'.....
    I tried to put just the "BASE64 APPKEY" text which is written in the email, as well. But same problem. So i don't know.
    Edited once, last by Danmann (December 4, 2016 at 2:26 AM).
  • Thank you,
    I have this name too
  • Thank you,
    Copy the .Key file, attached in the spotify email, in the right folder, after go inside the addon config: set your login info and use the alsa wizard. After do this all works fine for me. If you don't do this the local server on 4000 port will not work.
    Thanks to everyone.
    I don't know why but it's working now.
    I just installed the connect web again. But I did it before, too. So yeah, I don't know.
    Thanks.
    Edited once, last by Danmann (December 11, 2016 at 6:38 AM).
