Perfect, thanks!
LED (VFD) Displays in LibreELEC
The Coolest -
February 24, 2018 at 6:56 PM -
Hello, for a long time absent. Did you use vfd on mxv+ s905?
All supported (some are untested) boxes are in the vfd.conf repository.
Is the FD628 service only for OpenELEC? I'm currently using the latest CoreELEC and I got the clock working on my Sunvell T95 using the T95m vfd.conf file, but none of the other icons light up. I tried to find the FD628 service, but it's not available. Is it possible to manually install this add-on for CoreELEC?
Kashim You need to install the OpenVFD Service from the CE repository.
Thanks, that worked!
Hello! I got an U2C Z Pro (2/8GB, S905X) and tested the latest m9-pro-u2c-x-u5x-s-vfd.conf, but I can’t get it to work.
I found a dtb.img similar to my device. Someone over here contacted the official u2c seller on amazon.ca and got the official update file, containing the dtb.img. I’ll contact them, since mine is a U2C Z Pro, not U2C X Super, but the displays look exactly the same (without BT). The chip is a HBS658 and The Coolest mentioned it already over here: coreelec.org - Help with VFD.conf
Another thing I found is this: A user called hlyi published hbs658service on GitHub. I'm not sure how to compile, install it or if it's already included in the builds.
I also tried using gxm_q201_2g instead of gxl_p212_2g, since hbs658 it's mentioned here: GitHub Gist - aep / dts
But no luck.. It seems to be implemented for the S912 U2C devices, right?
Thanks. Config file added to the repo.
hi The Coolest
[Edit: just realized I opened an old thread]
I see following error on RK3399 TV Box:
CodeLoaded: loaded (/usr/lib/systemd/system/openvfd.service; enabled; vendor preset: disabled) Active: inactive (dead) Condition: start condition failed at Sat 2020-01-11 01:34:31 UTC; 15min ago └─ ConditionPathExists=/proc/device-tree/openvfd was not met Jan 11 01:34:31 LibreELEC systemd[1]: Condition check resulted in OpenVFD Service being skipped.
This is in manufacturer's DTS:
Codeskykirin_led { compatible = "skykirin-ht1628"; spi_clk = <&gpio1 RK_PB1 GPIO_ACTIVE_HIGH>; spi_cs = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>; spi_data = <&gpio1 RK_PB0 GPIO_ACTIVE_HIGH>; status = "okay"; };
Let me know how to fix this
Hello,
I have a QINTEX-Q912 box with Amlogic S912 and hbs658.
Is openvfd supposed to work with hbs658 ?
In the original dtb, i found only info about two gpios:
hbs658 {
compatible = "amlogic, hbs658";
dev_name = "hbs658";
status = "okay";
gpio-scl = <0x24 0x4c 0x00>;
gpio-sda = <0x24 0x4b 0x00>;
I suspect these are for vfd_gpio_clk and vfd_gpio_dat, but I could not find the one for vfd_gpio_stb.
Thank you,
Paul
P.S. I attached the full dtc of the box
Hello,
I got it working with bellow parameters, and the HBS658 controller is properly selected.
vfd_gpio_clk='0,76,0x10'
vfd_gpio_dat='0,75,0x10'
vfd_gpio_stb='0,0,0xFF'
vfd_chars='4,0,1,2,3'
vfd_dot_bits='0,1,2,3,4,5,6'
vfd_display_type='0x06,0x00,0x00,0x04'
The dmesg looks like this:
2445.369925] OpenVFD: Detected gpio chips: periphs-banks, aobus-banks.
[ 2445.369929] OpenVFD: is_right_chip periphs-banks | periphs-banks | 0
[ 2445.375018] OpenVFD: "periphs-banks" chip found. base = 401, pin count = 100, pin = 76, offset = 477
[ 2445.375021] OpenVFD: is_right_chip periphs-banks | periphs-banks | 0
[ 2445.381301] OpenVFD: "periphs-banks" chip found. base = 401, pin count = 100, pin = 75, offset = 476
[ 2445.381305] OpenVFD: Skipping vfd_gpio_stb evaluation (0xFF)
[ 2445.381306] OpenVFD: Skipping vfd_gpio0 evaluation (0xFF)
[ 2445.381308] OpenVFD: Skipping vfd_gpio1 evaluation (0xFF)
[ 2445.381310] OpenVFD: Skipping vfd_gpio2 evaluation (0xFF)
[ 2445.381312] OpenVFD: Skipping vfd_gpio3 evaluation (0xFF)
[ 2445.382999] OpenVFD: register_openvfd_driver: Succeeded to add openvfd module
[ 2445.388762] OpenVFD: Select HBS658 controller
[ 2445.388835] OpenVFD: SW I2C interface intialized (address = 0x0000 (N/A), LSB mode, pull-ups on)
Thank you,
Paul
Hi, guys! I had S78 box, this is a rikomagic rkm mk25 clone on S922x. I got working the HBS658 vfd. Below is a chunk from dtb and config:
hbs658 {
status = "okay";
gpio-scl = <0x2c 0x17 0x0>;
gpio-sda = <0x2c 0x18 0x0>;
vfd.conf:
vfd_gpio_clk='0,0x17,0x10'
vfd_gpio_dat='0,0x18,0x10'
