Add built-in Java support
  • I tested 1.1.2 and it works exactly the same as previous version regarding stability.
    No idea when it will be bumped.
    Gone...
    Thanks for your feedback. I tested the VLC player on Windows for some time. With the 1.1.2 libbluray integration BD menus work really good. Out of 20 iso files tested only 1 caused some trouble. I did not test the VLC player under Linux yet. Let´s check....
  • You need to build your own LE image because Kodi needs new libbluray library too. It is not just two .jar files.
    Gone...
  • OK so I wait for new version :)
    It seems that the latest libbluray version is not implemented in the latest libreelec release.
    Not a big deal, but would be nice to see if there is a more stable behavior.
  • :) I checked the functionality with the very latest KODI / Libreelec version. Huge improvement! It seems that many optimizations have been made on the video player side. Almost 80% of the BDJ menus worked on my Raspberry Pi 3+ (with the same JAVA add-on as before).
  • I tried the latest Libreelec Milhouse builds, which include the latest libbluray release as a major change.
    I also installed the JAVA add-on and the results were disappointing. Most BDJ menus did not work.
    Is the reason that the Zulu JAVA add-on needs to be updated / adjusted as well?
    BTW: Since this LE version the new libbluray release is included:
    #0802, 02-Aug-2019: Generic -- Release post (libbluray: update to 1.1.2)
  • LibreELEC master is still on 1.0.2: LibreELEC.tv/package.mk at master · LibreELEC/LibreELEC.tv · GitHub
    I would say Milhouse should update addon for his versions.
    As a workaround you could copy file libbluray-j2se-1.1.2.jar and libbluray-awt-j2se-1.1.2.jar to folder /storage/.kodi/addons/tools.jre.zulu/
    1. wget -O /storage/.kodi/addons/tools.jre.zulu/libbluray-j2se-1.1.2.jar http://vpeter.libreelec.tv/BD-J/libbluray-j2se-1.1.2.jar
    2. wget -O /storage/.kodi/addons/tools.jre.zulu/libbluray-awt-j2se-1.1.2.jar http://vpeter.libreelec.tv/BD-J/libbluray-awt-j2se-1.1.2.jar
    I see it funny how opposite results users have. One wrote "Almost 80% of the BDJ menus worked" and the other "Most BDJ menus did not work" :huh:
    Gone...
  • Well, the same user wrote this...:)
    Two different scenarios:
    a) LibreELEC 9.2.0 (Leia, final version based on Kodi v18.5) with ZULU Java add-on: works really well with >80% working menus
    b) LibreELEC (Milhouse) development builds (based on Kodi v19) with the same ZULU Java add-on: works really bad; most menus broken
    System: Raspberry Pi 3+ with Java add-on (tools.jre.zulu-9.0.101-RPi2.arm.zip)
  • Misses you wrote both posts :huh:
    Well, b) can't even works because jre addon doesn't have libbluray jar files ;(
    You need to add them like I wrote to get it running.
    Gone...
