February 13, 2018 at 3:03 PM #1 Hello,I bought a M8s Pro S912 with 3gb ddr4 Ram and installed LE 8.2.2.3 in the internal.But the Power LED on the M8S is very disruptive.Is there a way to disable the Power LED with a code?Thanks
March 13, 2018 at 12:02 PM #2 Hi Mate,Considering buying this unit. Can you tell me how it has worked out for you? Can you confirm it has Gbit LAN?Cheers
