It is not strange, it is normal. Saved on hardware and programming, typical "Made in Chi ...."
I do not think your device supports the real 1067 Mhz.
Please wait, I will compile another u-boot for you.
Display More...
PART II
1.
Run the system with sdcard1 or emmc.
Connect to your Box with SSH.
2.
In order to run the emergency system LE (u-boot.bin.sd.bin -> kernel LE -> SYSTEM) from the SD card, you need to change the boot sequence.
You can do this in many ways - destroy the eMMC-MBR + Bootloader, make a short circuit while holding the DAT0 <=> DAT1 pins directly on the eMMC chip, etc.
I will consider the first option, since it is available for less experienced users.
We execute commands one by one, please do not confuse the order of execution!
# set default environment
Sorry to be a pain but never done this before. Managed to connect to the box using WinSCP as per your instructions. To enter the command, presumably I have to start the Console (?) When I enter the command there, however, I get the following error: "Command ... failed with return code 0 and error msg 1+0 records in, 1+0 records out, 8MB copied." I guess that is not what should be happening?
copy the complete output from the console and post it here
use putty instead of winspc
Putty same result just no error:
LibreELEC (community): 8.2.2.3 (S912.arm)
LibreELEC:~ # dd if=/dev/zero of=/dev/env bs=8M count=1 && sync
1+0 records in
1+0 records out
8388608 bytes (8.0MB) copied, 0.145683 seconds, 54.9MB/s
LibreELEC:~ #
should I proceed?
Download u-boot.bin.sd.bin DDR4
- Get an extra sd card for testing
- Format this sd card in FAT 32
#Install
sudo dd if=u-boot.bin.sd.bin of=/dev/sdX bs=1 count=442 && sync
sudo dd if=u-boot.bin.sd.bin of=/dev/sdX bs=512 skip=1 seek=1 && sync
boot from sdcard
short pin 29 and 30 (see ) then plug the power adapter into the socket, after ~2 sec. release the pins.
Display MorePutty same result just no error:
1+0 records in
1+0 records out
LibreELEC:~ #
should I proceed?
that's right![]()
cheers
something is telling me this isn't tho (?):
LibreELEC:~ # dd if=/dev/zero of=/dev/bootloader
dd: writing '/dev/bootloader': No space left on device
8193+0 records in
8192+0 records out
4194304 bytes (4.0MB) copied, 0.185862 seconds, 21.5MB/s
LibreELEC:~ #
Everything okay
ah, ok, thanks. the box did NOT hang as expected, hence the question. will proceed with step 3 once I'm back home.
It was a precaution from me to warn you. In most cases, the box hangs after some time.
ehm, me again. the emergency SD card won't boot. what was I supposed to burn on it - the .tar.gz file, the .tar file inside it, or the .img file inside the .tar file?
when I try to extract the .img file, 7-zip says "cannot open file as tar archive, open as MBR archive." and then "unexpected end of data 1.img"
the .tar.gz file I was able to burn on the SD card but windows won't then read it and box does nothing when plugged in
Figured it out. To make your guide even a bit more idiot-proof, the part I missed was 1) you burn the .tar file to the card and 2) you have to start it using the toothpick method. Keep your fingers crossed for the final steps ![]()
Sorry, yandex disk automatically compresses the folders in zip format, I did not see that. I will update the link in the installation guide. You only need the * .img file
LibreELEC-S912.arm-8.90.6-h96pp-emergency-sdcard.img.tar.gz — Яндекс.Диск
Edit: Try this tutorial, use win32disk manager with "Verify" option. "Verify" is equivalent to the linux command "sync"
IT WORKS, THANK YOU SO MUCH!!!
just to add to my previous post that 3) wired connection did not work for me in the emergency system and had to use wifi, 4) in the last section of your code I figured there is a forward slash missing in dd if=dev/zero
Thanks for the info, the command is now corrected![]()
So,
what do you need to devise an u-boot image for the green CZ-S32-V2.2 H96Pro+?
Can i replace "u-boot.bin" inside LibreELEC-S912.arm-8.90.6-h96pp-emergency-sdcard.img.tar.gz with your "u-boot.bin.sd.bin" for DDR4 and use the emergency LE instead to short pin 29 and 30?
So i want to rename "u-boot.bin.sd.bin" to "u-boot.bin" and overwrite "u-boot.bin" on "SD card 2" with LE Emergency...
no, u-boot.bin.sd.bin must be written by the 0 sector
So,
Remote power trouble + remote factory_code and power key scancode.
