Install it from LE repository. You have to update os dependency 9.0.0 to 9.0.1.
please tell me how to do this?
I tried to update libreelec add-ons but I get no updates available
Go in addon, select 'Dependencies' button and install os.libreelec.tv 9.0.
I share your feelings on this, I spoke to kszaq about this just just a few days ago unfortunately not much can be done until we have fbdev mali blob for t820. The official response from Amlogic was they will not license these from ARM unless a customer requests it and pays the associated license fee. We have already been waiting over a year and there has been nothing yet, the only real hope we have is that another device comes out from another vendor that uses the same SoC and has the required blob and hope it is compatible.
I would recommend getting another device for now unfortunately.
Feel free to recommend other device, for libreelec with all-in future proof (I mean HDR and all that for my Oled 4k HDR tv including fancy new sound)
Nvidia Shield ![]()
Nvidia Shield
Ok thanks, I was considering that one or the minix. Most hasslefree i guess.
But i love booting direct to libreelec. Damn it. Ok, maybe return. Even if this latest test build and with advancedsetting.xml show improvment.
My 7 year old PC AMD fusion plays everything below remux and 4k better.
I can not click on Dependencies
Dependencies inactive
Minix is very good, it's all personal preference at the end of the day, maybe a device will come out in the future that shares the same GPU and has fbdev blob we can use but personally I'm more skeptical than hopeful.
Minix is half the price as well so it all depends what you want.
Try clean install on new SD card.
I tried, but in the last LibreELEC-S912.arm-8.90.11.img.gz there is no file dtb.img
Read #1, there is link for dtb files.
I made a clean installation LibreELEC-S912.arm-8.90.11.img.gz on the SD card
TrueHD/Atmos is not working with .11
Switched back to .10K which worked again
.11 was a fresh install from clean SD Card
Audio passthrough fix.
8.90.11a does not show the temperature
please tell me
what folder should I save so that I do not set up satellite channels every time?
Thank you
And for me the same, cpu temperature not show.
I've been happily using the builds provided in this forum for a while now and I can't complain in terms of performance and stability.
One inconvenience I would like to overcome would be the fact that I have to switch on the TV before turning on the KIII Pro. If not the screen will just stay completely black, even though Kodi works fine in the background (streaming through DLNA).
Is there a way to force HDMI (1080p) output to prevent this? I don't suppose this is some default available Kodi setting, but rather some sort of config for the box (if existing at all).
Audio fix worked , thank you very much for your efforts
