Unfortunately that did not work with the same results.
Here are some logs, maybe they can help.
i used your 4kfix img.gz (fresh install on SD using Rufus) from your GitHub, since the tar doesn't work (seems corrupted, gives me an error when attempting to extract after putting it in the update folder and restarting).
ok i will try force resolution after i build all weteks
