Where can I find a C2 with honest price? It seems that it's impossible to find one...
wrxtasy -
September 2, 2017 at 4:34 AM -
Closed -
No links to sellers allowed(forum rules)
C2 is at the end of lifecycle -> high price
Not really. From HK website:
QuoteWe guarantee the production of C2 to the end of 2019, but expect to continue production long after.
May be, may be not ...
I think there are only small quantities in current production
Just my opinion
Hello,
I'm trying to install Libreelect, i created the sd-card with Win32diskimager and copied and renamed the correct dtb.img for my MQX Pro (S905X) but i can't boot from the sd-card i tried the toothpick method and als with terminal emulator command but no luck i see S905X logo and after this menu but no Libreelect, any suggestions ?
Thanx Kris
recovery method (2nd variant): if you have "Update" app pre-installed open it, insert SD card with LE/connect USB drive, and choose any ZIP file in the app for update. Your box should reboot to LE.
No "update"-app in this rom :-c
No "update"-app in this romYour Boxe's Name ????I haven't heard of no updater in these China Roms.
It's in there. Sorry i have no box with Android installed.
Someone guide you how to get there.
kris.galle Your box has Rockchip SoC, you can't install LibreELEC on it.
So it's not a S905X ? So is it a fake but when it boots i get the S905X logo
Nope
Yes
Look at the Build RK = Rockchip.
Screw Driver + Open Box = Seeing is believing.
Send it back or get a full refund.
Ok thanx for the help.
i looked at the board -> R329Q DAMN
i'm returning it to the seller for a refund
better luck next time
Hi Guys,
Long time XBMC/Kodi/*Elec user here.
I'm choosing between S905D (with 1Gbit Eth) and S912 box. Any reason I whould choose S912 over S905D? Specs wise they seem to be the same except for GPU/3D graphics performance higher for S912 but I don't care about it as I believe this doesn't impct LibreElec performance.S905D belongs to the S900 family and all needed drivers/modules were released unlike S912, right? Should it perform better/be more stable compared to S912?
Also, S905D should use custom fork by Kszaq or official build?
Anyone with Mecool KI PRO to share experience how well and stable it does work?
Btw, Kszaq, are you maybe from Poland?
Thx!
For now there is no official build for generic S905 or S912 devices.
For LibreELEC S905/D/X is preferred over S912.
I actually have a friend with the same nickname, we studied IT together. Dzięki!
Btw, what about auto resolution/framerate switching? Only 1080p<->4K for entire S9xx line or maybe better for S905*?
