just reboot. It should be working ok
Is working, thanks for your work. I would add just a notification for the audio device switch.
Might be a good idea, thanks for the suggestion
Hi,
I was just looking for a solution for dual audio, between TV and Bluetooth headphones, because one of my relatives has very bad hearing, and cannot hear well the sound from TV unless it is extremely loud. Your add-on allows the TV and BT headphones dual audio, correct?
Can you please detail instructions for installing your add-on on LE 8.2?
Thanks!
Incorrect. It auto-switches to BT when a speaker (or headphones) are connected and switches back to normal audio when disconnected.
Ho,.. So my problem continues...
Hoping sometime in the future, a workaround which applies to my purpose will be developed.
Thanks anyway.
There are some "dual audio" LE builds in circulation on the internet. Not available from these forums, and not endorsed as a great idea (as the code is hacked up) but might suit your purposes. Google has details.
Are you saying that those builds may contain malware? They are not safe?
Nothing to do with malware, only unreliable hacking of the Kodi codebase. Just because something works, does not guarantee it works well.
OK, I understand now.
Can I ask you to explain me how to install the add-on of Isurak of this present thread?
The add-on is in the LE add-on repo.
