Okay...
How to transform my ts-lib functionality to a addon?
I think it is not very easy?
		Okay...
I mean I have to to make addon from this. Let me try in next days.
Hi
Okay. Thank you.
Maybe you explain it to me so i try to understand and to learn.
Which linux version you using? I tried some Ubuntu yesterday installed in virtual box.
Currently all this extra touchscreen stuff is build as part of the image. I did rewrote some parts and transform this functionality into addon. Will take few days to test and then I will give you the addon.
I'm using Ubuntu 14.04.5 LTS but v16 is fine too (64 bit of course).
Schorschi79, if you can try this addon I just made. I made only few tests and seems to be working.
Install addons manually
service.system.tslib-8.0.100.100-RPi-arm.zip
or
service.system.tslib-8.0.100.100-RPi2-arm.zip
and Estouchy skin
kodi-theme-Estouchy-17.0-beta1-81d5d26.zip
Then you need to configure it like described  in LibreELEC
follow steps in 7.1 regarding ts_env.sh file. The only change is that path is not
 but /storage/.kodi/userdata/addon_data/service.system.tslib. Skip autostart and calibration part. Just reboot and under addons look for calibration addon and calibrate screen. Immediately after calibration touch should work and you can switch to Estouchy skin.
I only have two special LVDS displays which works out of the box on Udoo imx6 board. I don't have any HDMI screen with USB touch but I know they work well when configured properly. The biggest I know of is 40" display on RPi used in museum used by visitors
UPDATE: rearranged few things and now I have service.system.touchscreen addon.
Hello vpeter, great work! Do you make this addon also for other platforms? I asume this one is only for the raspberry?
Do you make this addon also for other platforms? I assume this one is only for the raspberry?
Yes, this one is only for RPi. The idea is to put this addon into libreelec repository for everyone who needs it without requiring special image with everything included.
I need to make few more tests before that. If you need addon for some other platform let me know.
Hi vpeter,
thank you very much.
I test it tomorow because i am not at home and give you some request.
I'm using generic_64 on my Nuc's and I am verry happy that you decided to do an addon. So I don't need to compile for every beta...
Hi,
i try to test it.
But with the new Kodi i don't see my touchdevice in the eventlist.
So i can't Integrate the input/event number into the script 'ts_env.sh'.
Any idea?
I don't see my touchdevice in the eventlist.
Install System tools addon and run evtest program. There should be your touchscreen. Which one is exactly?
Hi,
Which Systemtools?
I installed your addon's and reboot my system. I also tested it without reboot.
Then run evtest to show all events. Bevore disconnected all my USB-devices. Only my touch is connected.
There were no events found. Kodi 17
With Libreelec 7.0.1 (kodi 16) and tslib integration i see my touch with the name
Dell ST2220 Multitouch
It looks like the kernel don't found any HID - Driver for my touch.
Hi
i installed System Tools addon.
But i don't see my touch in the event list.
Some other idea?
I put addon service.system.touchscreen in Index of /touchscreen/. It must be manually installed along with Estouchy skin.
To actually use touchscreen it must be manually configured. I would like to automate it or at least make more user friendly in the future but for now it is like that - follow post #59 for setting ts_env.sh and ts.conf. File can be edited on Windows over samba too.
After this 2 files are correctly set the system must be rebooted.
If all goes well I will put addon in libreelec repository for easy install.
Then it is not enabled in kernel? In which image it works and in which image it doesn't - so I can compare kernel config.
Hi,
the only image with Libreelec 7.0.1 for me that has working touch i uploadet.
Dowload : sJe8LdNIeBbx7kze4HQLfLVP0OtLEG4F0YEowwVKj1S?ref_=cd_ph_share_link_copy
All other versions without doesn't work. I hope my image is usefull for you.
I want use Kodi 17 with LibreElec and Amazon Addon.
Hello. My touch screen is this one HDMI/VGA + Conseil de Contrôle Pilote + 7 pouces AT070TN90 800x480 Écran lcd + Écran Tactile Pour Raspberry Pi + diy outils pas pour téléphone portable n dans Mobile Téléphone Lcd de Téléphones et Télécommunications sur AliExpress.com | Alibaba Group. It is very well set up and works fine with Raspbian. With libreelec 7.90 i do not come to the set, I have install the addon service.system.touchscreen and the addon estouchy, evtest recognizes the touchscreen, is what to say somewhere that the driver is egalax? Thank you.
sengol, then just configure this 2 files I mentioned above and it should work.
