Hello peeps,
For some reason the audio delay settings in my advanced settings.xml are not taking on playback. No delay is applied.
The same thing happens on all four installations of Libreelec i am running (on Asus Chromeboxes). Each require different delay as some are via Amps and some are on very laggy TVs.
Is something overriding the delay?
Help please!
file looks like this:
				<advancedsettings>
<network>
<buffermode>1</buffermode>
<cachemembuffersize>157286400</cachemembuffersize>
<readbufferfactor>20</readbufferfactor>
</network>
<video>
<latency> <!-- Compensate display latency (video lag). Latency is given in msecs. -->
    <delay>0</delay> <!-- Global default display latency -->
    <!-- Override latency for given display (not video) refresh rates. When Kodi is in windowed mode, override is ignored. Multiple overrides are allowed.
     Syntax of an override entry:
       <refresh>
         <min>, <max> refresh rate range, OR
         <rate> exact refresh rate
         <delay> display latency for the given refresh rate
       </refresh>
    <!-- Example: display has 125 msec latency at 23-24 Hz -->
    <refresh>
      <min>23</min>
      <max>24</max>
      <delay>-50</delay>
    </refresh>
    <!-- Example: display has 50 msec latency at 25 (+/-0.01) Hz -->
    <refresh>
     <min>25</min>
      <max>26</max>
      <delay>-50</delay>
    </refresh>
    <refresh>
     <min>29</min>
      <max>30</max>
      <delay>75</delay>
    </refresh>
 <!-- Example: display has 50 msec latency at 50 (+/-0.01) Hz -->
    <refresh>
     <min>50</min>
      <max>50</max>
      <delay>-50</delay>
    </refresh>
  </latency>
</video>
</advancedsettings>
			Display More
