Have you allowed BT adapter in Settings->LibreELEC ->Services->Bluetooth?
Sorry, finally i've syncronized it.
hallo
good news for kiii pro
oscam is working with latest dtv (android)
?94acgyt6jy6jfdz
install it
open it
and connect from pc
ipofbox:8888
exemple
192.168.1.5:8888
good luck
but this app not working in k1 and kii pro....
Display More
hallogood news for kiii pro
?94acgyt6jy6jfdz
install it
open it
and connect from pc
ipofbox:8888
exemple
192.168.1.5:8888
good luckbut this app not working in k1 and kii pro....
You posted most likely to wrong forum. This forum about LibreELEC not android. Oscam was always running in LibreELEC builds.
yes. thnks
he is just a information because is importante ![]()
Hello awesome people.
Does anyone know if i can use the Kiii Pro with DVB-C (ziggo netherlands), it is advertised as DVB-S + DVB-T but in some reviews it says it has the same tuner chip as other boxes that also support DVB-C. And if so can i use this libreelec build to set it up with DVB-C and a CCcam account?
I currently have a dreambox 900HDse and a android tv box (running kszaq's build s905x) but it would be nice if it could all be run in one box.
Thanks in advance
Djteaser
Hello awesome people.Does anyone know if i can use the Kiii Pro with DVB-C (ziggo netherlands), it is advertised as DVB-S + DVB-T but in some reviews it says it has the same tuner chip as other boxes that also support DVB-C. And if so can i use this libreelec build to set it up with DVB-C and a CCcam account?
I currently have a dreambox 900HDse and a android tv box (running kszaq's build s905x) but it would be nice if it could all be run in one box.Thanks in advance
Djteaser
Yes, DVB-C is supported in current LibreELEC builds. But recommended TV box for LibreELEC is KI Plus/KII Pro over KIII Pro.
Thanks! Is this because of the dvb tuner or is it s912 chip+libreelec related?
S912 chip+LibreELEC related, see the first post in the thread for more information.
Ah ok thanks, i'l try the Kii pro then
Or wait for KI Pro with S905D.
Sent from my Nexus 4 using Tapatalk
Or wait for KI Pro with S905D.Sent from my Nexus 4 using Tapatalk
Are there many benefits to this box?
S905D is basically S905X with DVB support and more likely to be coupled with Gigabit Ethernet, that's why I think it's interesting. I cannot speak about the box, I don't have any of "K" boxes.
Let's end this offtopic. ![]()
Update in #1.
Test version with fixes in faster channel switching:
LibreELEC-S912.arm-8.0-8.0.1-devel-20170516112042-g6e79ad4-I.tar
Another test version for faster channel switching:
LibreELEC-S912.arm-8.0-8.0.1-devel-20170517142818-g6e79ad4-I.tar
I'd love to start testing but I'm still waiting for my S912 to arrive, I expect it'll will the beginning of next week. I just wanted to thank you for your continuing efforts already though.
What are the differences with the op version? Is it possible to add this improvements in the "original" version?
As the message states, as well as the post before that: it is a test version with just a fix for faster channel switching...for you to test if it works properly. If you test it, your feedback will help to decide if the fix can be included in the regular builds.
