Compile Sapphire remote driver
  • Thanks,
    I installed the addon.
    I reboot the device and the module is loaded:
    # lsmod | grep sapphire
    sapphire                7175  0
    But the keys works as worked before install the addon, I change the "nano /storage/.kodi/userdata/addon_data/driver.remote.sapphire/sapphire.keymap" file but nothing happens.
    Need I configure or disable the original module?
    Thanks and regards.
  • If you change the keymap you will have to restart the computer.
    Thanks Irusak,
    I change the "Clear" key to work as "C" this way:
    # cat /storage/.kodi/userdata/addon_data/driver.remote.sapphire/sapphire.keymap | grep CLEAR
    SAPPHIRE_CLEAR           KEY_C            NO_REPEAT                    ## Contextual menu
    I reboot the computer, but nothing works. If I push the CLEAR key in the remote it doesn't do nothing. If I push the C key in the keyboard it show the contextual menu.
    I am doing something wrong?
    Best regards.
  • Hello again,
    I upgrade to v7-90-004-alpha and have same problem, it doesn't wotk.
    I notice that when I reboot the device I have this message in boot output:
    Quote
    [FAILED] Failed to start Sapphire remote start script.
    See 'systemctl status driver.remote.sapphire.service' for details.
    This is the details:
    In the "dmesg" I have this:
    # dmesg | grep sapphire
    [    6.825862] sapphire: version magic '4.6.3 SMP mod_unload ' should be '4.7.0 SMP mod_unload '
    Thanks for your help.
    Kind regards.
