Hello, i have an Odroid C2 and want watch some DVD Iso files. The problem is, that the iso files did not run. If i open this file, i hear music but did not see a Menu. I have this with some DVD/Iso files. On Raspberry Pi it's run very well.
Here is my Log file
13:10:00.778 T:548088049664 NOTICE: special://profile/ is mapped to: special:// - Pastebin.com
I have also tested it on another amlogic board (Mecool HM8 TV Box Amlogic S905x)and have the same Issue.
It's run with an old Jarvis 16.1 Build from User Wrxtasy (on Odroid C2)
DVD iso did not work (Odroid)
Mister XY -
March 12, 2017 at 12:20 PM -
- Official Post
Using illegal repositories like 'unofficial-sports-devil' are not really encouraging us to help.
i removed it.
No reaction about this error?
- Official Post
We probably need a new log
- Official Post
Seems the iso is kind of broken:
Line 1175:
14:25:18.847 T:544990294240 WARNING: CDVDInputStreamNavigator::GetVideoResolution - Failed to get resolution ()Line 1209:
14:25:18.902 T:544990294240 WARNING: CDVDInputStreamNavigator::GetVideoResolution - Failed to get resolution (Couldn't open IFO for chosen title, exit.)Line 1282:
14:25:19.333 T:544990294240 WARNING: VideoPlayer::Sync - stream player video does not start, flushing buffersThe missing ifo-file might be the problem in that case.
The Iso is 100% Correct because i can play it with raspberry pi, orange pi, It's run with an old Jarvis 16.1 Build from User Wrxtasy (on Odroid C2). The problem is, that is not only one DVD/Iso that is not play, i have more ISO that did not play under LE 8. Under LE7 is play fine.
Here is the same DVD play with fresh installed 7.1.3 from user Wrxtasy on my Odroid-C2.
04:43:15 T:548167827456 NOTICE: special://profile/ is mapped to: special://mast - Pastebin.comIs it possible, that the libary that open ISO files are broken?
I don't know how it's possible but this came from Wrxtasy.
Quote
For info I use an old Koying .vob patch in LE 7.1 that defaulted to Software decoding and YADIFx2 Software deinterlacing for problematic mpeg2 DVD .ISO's
.ISO's that contain mpeg2 .vob files. -
No solution?
I have actually installed agile10 from Raybuntu and all ISO run fine.
Release rb-agile10 · Raybuntu/LibreELEC.tv · GitHub
