Video playback does not depend on Mali drivers.
						kszaq
					March 3, 2017 at 7:18 PM
			hello, I'm waiting for a s905x box. In order to see my 4k HDR 10bit video, I have only to insert this command line in autostart.sh ? echo '444,10bit' > /sys/class/amhdmitx/amhdmitx0/attr
			That is from the media box part. Do you have a TV/monitor, which supports YUV444, HDR and 10bit?
			That is from the media box part. Do you have a TV/monitor, which supports YUV444, HDR and 10bit? Yes I have a new 4k hisense tv with hdr
			How can I check in the setting is applied? thank you
			hello, I'm waiting for a s905x box. In order to see my 4k HDR 10bit video, I have only to insert this command line in autostart.sh ? echo '444,10bit' > /sys/class/amhdmitx/amhdmitx0/attr Wrong thread for discussing that device. This thread is s912 related.
			Hi kszaq thanks for you hard work I update from 8.1.1 to 8.1.3 but i have no internet on the box but is connected with the wifi, im back to 8.1.1
			I'm using 8.1.2 (KIII pro s912) and some channels like HBO has a subtitle out of sync (3sec). (Using TVheadend dvb-c)
			Hello i need a working device tree for my Minix U9-h. For 8.0.2e (2017-07-04) simple delete the dtb.img and thats all.....working for me on my U9-h. This works only on 8.0.2e and previous versions.
 For 8.1.3 (2017-08-06) no boot...........I need a working device tree. King regards
			Hi, I have a KIII PRO s912 8.1.2.. Is there any way to update for 8.1.3? Or I need to format and reinstall everything?
			or without PayPal account: link Hi Mateusz, This link doesn't work for me. Do you know why? File “4yr59 2017-08-09 10-12-04.png”
			Is there any way to update for 8.1.3? Read Updating section here
			Screen calibration is OK, menu interface is OK, but there are overscreen when info bar showed while movies play
			Try to correct the picture size from the TV picture settings.
			I agree, you should try to find the correct settings on the tv and not use the kodi screen calibration at all unless you really need to. Some tvs require you to set the hdmi port as "PC" or "computer" to disable overscan. Best check online with your tv model nr.
			Hello i need a working device tree for my Minix U9-h. Has someone here a Minix U9-h with functioning device tree? Minix U9-h hangs on boot. King regards
			Try to correct the picture size from the TV picture settings. I fix it. Thanks, you are right mmpp, thanks
