Thanks a lot for the congratulations. Coming from you, it means a lot, as I am absolutely not a developer. I had to do this, step by step with Gemini, not in agent mode (I don't even know if it supports it), lots of trial and errors... I was lucky that Thorium's patches were well documented. 95% of the work is from that developer (which I've discovered after I finished this work that will probably provide modified Electron builds, maybe those might be of interest to you, in case you don't want to include mine).
What other goodies did you have in mind?
I don't know if I mentioned I am not a developer LOL. after your work I'd say I'm lower than you when it comes to vibe coding! you even set up your own repo which I haven't yet. haha so yeah we in the same boat. I don't even read the code.
I'm currently feeding your repo and it's work into ChatGPT plus. I'm seeing if I can add your work into windows build plus the work I got earlier which was 5.1 not in Dolby, having both will be great and able to switch when you want. not sure I can get as close to your work, plus I haven't got LibreELEC installed.
Other goodies.
-decide what loads when vacuumtube starts, I've got this down, I can load into any menu, including subscriptions
-default quality of video playback
-hide watched videos
-ability to long press on related videos to see menu where it shows add to playlist etc
-I'm looking into adding a queue so in the context menu on videos we can queue videos
-miniplayer at bottom, I've got this working! it loads a second window, it's allowed in electron, look into.
these are the ones I can think of, but the true bea uty is , we can add lots of things , pick what you think will add to your experience. it's shaping up to be a great YouTube Addon! we just need HDR now
