Dolby Vision 1 Hardware
  • I found a new one:
    GEEKOM A5 Pro
    • AMD Ryzen 5 7430U Prozessor
    • 16 GB DDR4 RAM
    same price like the Core Ultra 5 125H. (seller has stopped responding me)
    How should the suitability or graphics performance be evaluated?
    Do CroqueMr and LibreELEC-Hades have the same hardware requirements?
    I don’t even know which version I should choose.
  • I don't think we have the same hardware requirement. For my build a recommand 3500U/R2254 or above. 7430U is perfectly fine.
    And I have a 7430U on my test bench it handles properly everything.
  • starting Saturday in UK you can get the GMKtek 3500U for £87.95 ($117.17)
    GMKtec G10 Barebones Mini-PC ( AMD Ryzen 5 3500U / DDR4 SODIMM / Dual M2 slots / 2.5GbE ) w/code @ GMKtec Direct Store(UK Despatch)
    This preview deal starts at 5pm on Saturday. Use code UKJUNEBD15 at Checkout. Despatched from a UK warehouse.Uses plentiful DDR4 SODIMMs and has dual M2 SSD
    www.hotukdeals.com
    even mentions Kodi, I'm still holding out for 11.11, might get full system for $140. like to see how much K12 goes for to
  • Be careful It's a barebone mini pc without ram & ssd.
    yeah thanks, I forgot to mention that. this is why I'm hopeful come 11.11, we'll get a complete system for $140.
    also on ebay look for 2 x 4GB DDR4, can be had for £21 which takes it to £109, storage you might already have or pay another £15
  • I wrote this in kodi forums
    I'm curious so did some research, the Intel Core i5-1235U features 8 efficiency cores (E-cores) alongside 2 performance cores (P-cores). base clock 1.3 GHz
    It's GPU is 25% more powerful as the 3500U iGPU. it's one process node ahead of 3500U. with twice single core speed
    It's very common in used laptops in Ebay and has native HDMI I believe? It's market price is around £80 if you check sold.
    Here is just a quick example
    https://www.ebay.co.uk/itm/307117791029
    to get full GPU out of this, you need to add another 8GB RAM, add a charger, and we are around £120 ($165)
    Then disconnect the screen and battery, touchpad and keyboard. remove the battery. flip it upside down while keeping the chassis,
    the motherboard on this model is a good shape, you could if you have the tools and the skill create a custom case for this. or just go the lazy route like I've mentioned. Cooling wise it probably is quieter than a miniPC running 3500U because of e cores and better process plus just more space in the laptop with the heat pipes more distance away from SOC.
    what are your thoughts, on using used laptops with this SOC?
    ____________________________________________________________
    this might not be a bad way to get this. this is far better than 3500U at cheaper. it's more like a 5500U probably
  • Thank you for the work being done here.
    So, what's the best mini PC to get if money really isn't a problem? I don't care if it's overkill; I just want the best hardware to run those builds.
    anything past AMD Ryzen 3500U will meet requirements of running it. getting a more powerful system won't improve image, just give you a faster experience on kodi, but there comes a point of diminishing returns. I think look out gor a gmktek k12 in aliexpress sales on 11.11. most likely barebones and just add your own ram and ssd. some great deals will come up.
    go on a deal site like slickdeals (usa) hotukdeals (uk).
    should be able to get a beast of a system for $350. more power than you know what to do with.
  • Hello folks. I'd rather not dublicate the thread so i found this existing topic and ask my question here.
    I am also somewhat interested in this option.
    I wont have a separate PC for this, i would rather load libreelec from my main PC using bootable SSD with USB adapter.
    My discrete nvidia rtx 4000 series GPU is connected to TV directly, i also have iGPU within 9800x3d CPU and i already use motherboard HDMI to output sound to my AVR.
    I saw RDNA 2 being listed as supported, Ryzen 9800x3d iGPU is based on RDNA 2.
    Would iGPU of Ryzen 9800x3d be good enough to handle Dolby Vision Master Reference, and also "reference" conversion to HDR10\HDR10+ ?
    The PC has 2x24 of DDR5 installed at 6200 mt and tuned timings, how much RAM should i set in BIOS for iGPU if i want this to work without stutters, frame skips and out memory errors, but also not take too much RAM from main windows 11 boot? The minimum that can be set is 512 mb - too little?
    I also imagine this will be tasking on iGPU, but there is little reason to worry about heat and noise since entire PC is water cooled.
    Thank you.
  • A 3200U with 8gb of DDR4 single channel at 3200mhz, with a lower iGPU and far weaker CPU handle the master reference pipeline perfectly. even at 60fps with gemini man for example
    The only limitation are for conversion/enhancement pipeline >30fps.
    DV to HDR10+ is not working as intended it will be fixed shortly, but conversion to HDR10 is very good and stable
    I think you should not have any issue with your CPU, even if the iGPU is not very powerful. Also I will try to rebuild and optimize deeply the conversion pipeline after the stable release next month, it should help a the small iGPU.
  • DV to HDR10+ is not working as intended it will be fixed shortly, but conversion to HDR10 is very good and stable
    As of now i have LG OLED with tv led DV, but i plan to get Samsung in 2027 so thats why i am asking.
    Also, current solutions such as am6b+ (which i own) already provide DV to HDR10 conversion with FEL, what would be the benefit of converting to HDR10+ using your method? Is this similar to LLDV with CM 4.0 that exist on recent avdvplus?
    What do you think about the amount of memory that needs to be set for iGPU, like, to handle the most hardware intensive remux with FEL and HDR10\10+ conversion? Thank you.
  • As of now i have LG OLED with tv led DV, but i plan to get Samsung in 2027 so thats why i am asking.
    Exactly, In my build, DV to HDR10 Expert is designed to deliver something close to what you get with an AVDVplus. That's the whole objective.
    The algorithm is already really clean, and Expert mode can run at 30fps on a low-end CPU. But keep in mind, this is one of the most GPU demanding pipelines.
    I could push it even further with true Master Reference LLDV rendered as HDR10. I'm not sure the visual improvement over the current Expert mode would be that significant, though, and it would require MUCH more GPU power or massive optimizations.
    I might take on that challenge after the stable release, but I'd recommend waiting until you upgrade your TV. By then, we'll have a better idea of the mini PC requirements.
    As for HDR10+, it should deliver similare result as LLDV over HDR10, but in a more user-friendly way: no manual display settings, and likely lower GPU requirements.
  • I might take on that challenge after the stable release, but I'd recommend waiting until you upgrade your TV. By then, we'll have a better idea of the mini PC requirements.
    Sure. I dont need it for LG, As of now i might just use it as tv led source.
    Just to see how it runs compared to am6b+. How much snappier UI will be an all that.
    If 9800x3d will end up working well, i will be happy to get rid of the extra device. I'd be a happier person if i could just use a single PC for everything, even if it needs to be rebooted into libreelec to watch a movie.
    My question about RAM pool for iGPU still stands unanswered though :(
    How much should i dedicate from 48 gb of DDR5 to be used as video memory? Whatever ammount i set in BIOS will be unavailbale in main Windows 11 boot. I'd like to use as little as possible, but i imagine 512 mb wont be enough, so 1 gb? 2 gb? :/
  • Sure. I dont need it for LG, As of now i might just use it as tv led source.
    RAM is not a bottleneck don't worry about that. a 3200U with single channel and standard DDR4 bandwith is sufficient.
    Edit I did not saw your question properly : I recommand 4gb to be confortable and safe
