Good luck! ![]()
[RPi] ConnMan resource socket leak (1024 FD crash) when using kernel-space WireGuard (wg0)
Doemela -
July 20, 2026 at 1:25 AM -
To help other community members check if their systems are suffering from this ConnMan file descriptor leak, I have written a diagnostic script. Connect via SSH and create the script:
Paste the following code inside the file:
Bash
Display More#!/bin/sh # chmod +x /storage/.config/scripts/connman-leak-test.sh # /storage/.config/scripts/connman-leak-test.sh OUTDIR=/storage/.cache/connman-diagnostics-$(date +%Y%m%dT%H%M%S) mkdir -p "$OUTDIR" PASTE_LOG="$OUTDIR/connman-leak-test.txt" trap 'echo -e "\n[$(date +%H:%M:%S)] Execution interrupted by user! Jumping to final metrics collection..."; break' INT echo "=== CONNMAN DIAGNOSTICS (PASSIVE MONITOR) ===" > "$PASTE_LOG" echo "OS: $(cat /etc/os-release | grep PRETTY_NAME | cut -d'"' -f2)" >> "$PASTE_LOG" echo "Kernel: $(uname -r)" >> "$PASTE_LOG" if [ -f /proc/device-tree/model ]; then echo "Hardware Model: $(cat /proc/device-tree/model)" >> "$PASTE_LOG" fi echo "----------------------------------------" >> "$PASTE_LOG" pid=$(pidof connmand) echo "Connmand PID: $pid" >> "$PASTE_LOG" echo "[$(date +%H:%M:%S)] Toggling Kodi component debug logging ON..." kodi-send --action="SetLogLevel(2)" >/dev/null 2>&1 || true echo "[$(date +%H:%M:%S)] Collecting FIRST snapshot (T=0)..." echo "=== SNAPSHOT 1: START ===" >> "$PASTE_LOG" echo "Timestamp: $(date)" >> "$PASTE_LOG" if [ -n "$pid" ]; then echo "FD count: $(ls -l /proc/$pid/fd 2>/dev/null | wc -l)" >> "$PASTE_LOG" echo "Active FD targets (Top 20):" >> "$PASTE_LOG" (for f in /proc/$pid/fd/*; do readlink -f "$f" 2>/dev/null || readlink "$f" 2>/dev/null; done ) | sort | uniq -c | sort -nr | head -n 20 >> "$PASTE_LOG" 2>&1 || true fi echo "----------------------------------------" >> "$PASTE_LOG" echo "[$(date +%H:%M:%S)] Sleeping for 30 minutes to let the leak accumulate..." echo "Press Ctrl+C at any time to skip the wait and generate the log immediately." for i in $(seq 1 1800); do sleep 1 done trap - INT echo "[$(date +%H:%M:%S)] Collecting SECOND snapshot (T=+30 min)..." echo -e "\n=== SNAPSHOT 2: AFTER 30 MIN ===" >> "$PASTE_LOG" echo "Timestamp: $(date)" >> "$PASTE_LOG" if [ -n "$pid" ]; then echo "FD count: $(ls -l /proc/$pid/fd 2>/dev/null | wc -l)" >> "$PASTE_LOG" echo "Active FD targets (Top 20):" >> "$PASTE_LOG" (for f in /proc/$pid/fd/*; do readlink -f "$f" 2>/dev/null || readlink "$f" 2>/dev/null; done ) | sort | uniq -c | sort -nr | head -n 20 >> "$PASTE_LOG" 2>&1 || true if [ -r /proc/net/netlink ]; then echo -e "\n=== /proc/net/netlink ===" >> "$PASTE_LOG" cat /proc/net/netlink >> "$PASTE_LOG" fi fi echo -e "\n=== RECENT KODI LOG ENTRIES FOR ADDON ===" >> "$PASTE_LOG" if [ -f /storage/.kodi/temp/kodi.log ]; then grep -Ei "connman|wireguard" /storage/.kodi/temp/kodi.log | tail -n 150 >> "$PASTE_LOG" 2>&1 || true fi echo -e "\n=== RECENT SYSTEM JOURNAL LOGS FOR CONNMAN ===" >> "$PASTE_LOG" journalctl -u connman.service -n 150 --no-pager >> "$PASTE_LOG" 2>&1 || true echo "[$(date +%H:%M:%S)] Toggling Kodi component debug logging OFF..." kodi-send --action="SetLogLevel(0)" >/dev/null 2>&1 || true echo "----------------------------------------" echo "Uploading results..." PASTE_URL="" if command -v paste >/dev/null 2>&1; then PASTE_URL=$(paste "$PASTE_LOG" 2>/dev/null) fi if [ -z "$PASTE_URL" ]; then echo "Deploying curl fallback to ix.io..." PASTE_URL=$(curl -s -F "f:1=@$PASTE_LOG" ix.io) fi if [ -n "$PASTE_URL" ]; then echo "----------------------------------------" echo "Your diagnostic paste link is:" echo "$PASTE_URL" echo "----------------------------------------" else echo "Upload failed. Log preserved locally at: $PASTE_LOG" fiSave and exit (Ctrl+O, Enter, Ctrl+X), then give it execution permissions and run it:
Shell sessionchmod +x /storage/.config/scripts/connman-leak-test.sh /storage/.config/scripts/connman-leak-test.shIf you let it run full course or interrupt it, it will provide a direct paste link showing if your system is experiencing un-canceled socket tracking build-ups.
The patch looks structurally okay to me now, but I can't speak for the code. Denis and Marcel seem to be less active at the moment and I'm not sure if they are still working at Intel or were laid off, which might slow things up (not that ConnMan has been quick in recent years). If there is no comment in a week you might need to reply to your own email submission with a brief apology for the five previous messy iterations, and politely asking for feedback. If we see some positive feedback then I'm happy to pick the patch into LE images until ConnMan sees a version bump that includes it.
UPDATE 2026-09-20: Fixed — patch submitted upstream
Confirmed the leak on stock LE13 nightly 20260920-b68ee23 (ConnMan 2.0, iwd backend, Generic x86_64): fd count 22 → 49+ over VPN cycles, never recovers. Root cause in plugins/wifi.c interface_removed() — early-return skips g_supplicant_interface_cancel().
Patch (v7) submitted to [email protected]. With patch applied: fd returns to baseline (22) after every cycle. Verified data + fix instructions: Upstream ConnMan FD Leak Automated Mitigation Guide
In the v7 submission everything below the first paragraph should have been placed under the --- separator so that it is visible to reviewers but not merged into the codebase along with the description.
I normally place things above --- during development so that testing commentary is easily edited and not forgotten, but then you need to remember to tweak the final patch files before sending to move the --- above it.
Ty v8 submitted with the commentary moved below the separator.
Additional data point: reproducible trigger for the UDP :53 leak via a failed online check (no WireGuard)
Setup: RPi2, LibreELEC 12.0.2 (ConnMan 1.43), WiFi only, no VPN/WireGuard, default online check settings ("one-shot", geometric interval [1, 12]).
Symptom: after ~35 days of uptime connmand had ~1015 of 1024 FDs open, followed by "Failed to open/bind time server socket" flooding the journal and NTP no longer syncing.
Findings:
- During normal operation there is no leak at all. connmand stayed at 17 FDs for 23 hours.
- Clean WiFi reconnects (connmanctl disconnect/connect, 3 cycles) don't leak either. FDs go 17 → 12 → 17 every time and all sockets are closed properly.
A single failed online check does trigger it. I blocked outbound HTTP with
and reconnected the WiFi. The service stays in "ready". After the first check times out (~2 min), every retry fails immediately with
Each retry leaves one more UDP socket to the DNS server (router:53) open. FDs went 17 → 24 within ~12 minutes (UDP :53 sockets 3 → 9+).
- The online check never recovers by itself. After removing the iptables rule it kept failing with -22 for another 7 minutes (and presumably forever, retrying at up to 144 s intervals), leaking one socket per attempt. Only restarting connman fixed it, after which the check succeeded immediately and FDs were back to 17.
So on my system the chain is: a short internet/connman.net outage → online check stuck in -22 → endless retries → one leaked UDP :53 socket per retry → FD limit reached after a few days → NTP dead. A clean reconnect isn't enough to start it, it needs the check to actually time out.
The ConnMan 1.44 changelog has "Fix issue with handling web context for online detection", and that release reworked the failure path in src/wispr.c / gweb. It might be related, but I haven't tested 12.2.x / 1.45 yet. The iptables rule above should be an easy way for anyone on 12.2 or 13 to check whether it still happens there.
Workaround for now: EnableOnlineCheck = false in /storage/.config/connman_main.conf (CamelCase, [General] section), then restart connman.
Update: still happens on LibreELEC 12.2.1 / ConnMan 1.45
I updated to 12.2.1 (ConnMan 1.45) and repeated the same test (iptables DROP on outbound tcp:80, then WiFi reconnect). So my guess about the 1.44 changelog was wrong. The bug is still there, only the error message changed:
Code21:52:58 IPv4 online check to http://ipv4.connman.net/online/status.html failed: Input/output error 21:52:59 No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for wlan0 [ wifi ] online check URL http://ipv4.connman.net/online/status.html 21:52:59 IPv4 online check to http://ipv4.connman.net/online/status.html failed: no valid proxy ... (repeats at growing intervals)- The first check times out after ~2 min (Input/output error). After that, every retry fails immediately with no valid proxy.
- Each retry still leaks one UDP socket to the DNS server (router:53). connmand went from 20 to 29 FDs in ~11 minutes.
- It doesn't recover after the block is removed. I waited another 5+ minutes and it was still "ready" with no valid proxy on every retry. Restarting connman fixes it immediately.
So in 1.45 the failure path seems to switch to WPAD/PAC proxy discovery. The PAC URL is derived from the DHCP domain (fritz.box, my AVM router doesn't provide a wpad.dat). It then never falls back to a direct request again, and every attempt leaves a resolver socket open.
Workaround is unchanged: EnableOnlineCheck = false in /storage/.config/connman_main.conf ([General] section), then restart connman.
