[x86-64][LibreELEC x CB1 Builds] Dolby Vision FEL, HDR10+ and Full 3D
  • So, I'm amazed this 3D 4K FSBS is playing perfectly using this build w/AMD H255 with my Titan Noir Max projector:
    Yes, it's outputting at 1920x2205, but fact that it can play it is amazing. Believe NexiGo MKII can actually play 4K 3D.
    Edited once, last by ht2tweak (November 22, 2026 at 7:53 PM).
    you're running dual 4k with OSD on at 1%CPU and 92 degrees f, your firecube 3rd gen runs hotter on just idling
    don't know what to say. #pcmasterrace
    CroqueMr you really have done something incredible that will have effect on so many people and businesses. take a bow
    ht2tweak your player cache is full, is it possible you could increase it? you have enough spare RAM
  • You're right, didn't check that bit. This is what Gemini suggests; look right?
    <advancedsettings version="1.0">
      <cache>
        <memorysize>268435456</memorysize>
        <buffermode>1</buffermode>
        <readfactor>0</readfactor>
        <chunksize>131072</chunksize>
      </cache>
    </advancedsettings>
  • Player cache being full is a good thing, you don't have to change anything.
    You can also change it in the GUI, Settings / Services / Caching but don't bother.
    Edited once, last by nissel (November 22, 2026 at 9:27 PM).
      <cache>
      </cache>
    </advancedsettings>
    yeah Google AI said cache being full is what is supposed to happen, but said LibreELEC can still give more buffer since you have so much but not sure what that will do ^^
    Almost spot on, though you'll want to tweak a couple of things—here’s why:
    1. Change <readfactor>0</readfactor> to 10 (or Adaptive):
      • Why: Setting readfactor to 0 disables fast read-ahead and forces Kodi to trickle-fill the cache at barely above real-time playback speed. Since your file is streaming at 65.8 Mb/s (~8.2 MB/s) over the network, 0 makes it struggle to build a buffer—especially right after skipping forward. Setting it to 10 lets Kodi burst-read over your network so the buffer fills in seconds and stays full.
    2. Bump <memorysize> to 512 MB (536870912):
      • Why: At 8.2 MB/s, Kodi's default tiny cache only holds about 3–5 seconds of video—so any brief Wi-Fi dip or NAS drive spin-up will cause a stutter. Bumping it to 512 MB (which reserves ~1.5GB of your 16GB RAM) gives you roughly a 60-second safety cushion ahead of playback without touching your CPU or fan noise.
    3. Check your LibreELEC / Kodi version first:
      • Why: Starting in LibreELEC 12 (Kodi v21 Omega), Kodi completely ignores <cache> tags inside advancedsettings.xml because they moved those settings into the GUI.
    If you're on LibreELEC 12+ (Kodi v21 or newer), set it in the menu instead:
    • Settings > Services > Caching
    • Buffer mode: Buffer all filesystems (ensures mapped network/SMB shares get cached)
    • Memory size: 512 MB
    • Read factor: Adaptive (or 10x)
    • Chunk size: 128 KB (reduces network overhead on large high-bitrate files)
    If you're on LibreELEC 11 or older (Kodi v20 and below), use this updated XML:
    xml
      <cache>
        <memorysize>536870912</memorysize>
        <readfactor>10</readfactor>
      </cache>
    </advancedsettings>
    Use code with caution.
    ht2tweak Gemini said this
    Edited once, last by hcliec001: Merged a post created by hcliec001 into this post. (November 22, 2026 at 9:26 PM).
  • hcliec001 i set all things to maximum, cache, chunk size, etc etc etc. i dont need AI advise for this.
    why? because we (or most of us) have more than enough RAM (8g or more).
    for example, read factor...i set it around 40.
    cache size 1gb,
  • CroqueMr - Tested your latest build with both my 4650GE and 3400GE m75q PCs today.
    • The 4650GE handled all passthrough and conversion combinations with ease. As low as 10% GPU usage for passthrough and up to 40% GPU usage for conversions (DV to HDR10, HDR10 to SDR) … with high 40s/low 50s temps.
    • The 3400GE did ok, but had higher GPU usage up to 80% and temps in the low to mid 60s.
    One odd bug. My Anthem 1140 was unable to identify the video signal and would only display “other” for 4K24. Yet the JVC identified the signal properly.
    4650GE
