Btw: what's the command to open emulationstation from the main menu? I want to use the mod version of the skin instead and want to add a possibility to launch it from there.
I will try the new build and the command after the formula 1 race.
escalade -
May 12, 2016 at 2:26 PM -
Thread is Resolved
It's "emulationstation.sh".
RetroArch and Emulationstation are now starting every game correctly. Still no sound.
I closed down kodi and triedspeaker-test
Codespeaker-test 1.1.1 Playback device is default Stream parameters are 48000Hz, S16_LE, 1 channels Using 16 octaves of pink noise Playback open error: -2,No such file or directory
No sound was played.I also tried again
aplay -LCodenull Discard all samples (playback) or generate zero samples (capture) hdmi:CARD=HDMI,DEV=0 HDA ATI HDMI, HDMI 0 HDMI Audio Output
this is how my "\.config\asound.conf\asound.conf" looks like:
Codepcm.!default { type plug slave.pcm { @func getenv vars [ ALSAPCM ] # Device name can be found using the command 'aplay -L' default "hdmi:CARD=HDMI,DEV=0" } }
Anything missing?
Also just emulationstation.sh as a user setup command triggered via main menu isn't working.
I just seem to need the complete stuff, that is behind you main menu button. -
You've got a linebreak with the same device following on the next line. Look at the sample I've provided and compare. You've also put it in the wrong place, it should be directly under .config, not in an asound.conf subdir. "emulationstation.sh" is behind my main menu button.
The linebreak was a wrong c+p.
All the other stuff is on hold for me, since I gave the system back to my friend, the owner (I fixed some hardware and completely reinstalled the system, also rescraped the complete library etc.).
But in a few days I will also reinstall my system ( a more powerfull config and also a AMD one) so I will be back for some tests.
Thanks for all the work you have done so far! -
Hi escalade,
Thank's for new builds.
I start transmission as you say, but when i acces from webui (IP_RPi:9091), appears:Code403: ForbiddenUnauthorized IP Address.Either disable the IP address whitelist or add your address to it.If you're editing settings.json, see the 'rpc-whitelist' and 'rpc-whitelist-enabled' entries.If you're still using ACLs, use a whitelist instead. See the transmission-daemon manpage for details.
where is transmission's "settings.json" file?
or how i could modify it?
Hi escalade,Thank's for new builds.
or how i could modify it?It's done!! I found it !!
i stopped transmission ( systemctl stop transmission), modified "settings.json" , and restart transmission (systemctl start transmission)
The file "settings.json" is located at:
/storage/.config/transmission-daemon/settings.jsonand i modified the line --> "rpc-whitelist" to:
"rpc-whitelist": "*.*.*.*",
and that's all!!! -
I'm testing your last build. 20160711
I have a XBOX 360 wired controller that not working in "emulationstation" menu (i need to use a remote keyboard "Rii mini")
With retroarch, it works ok, and in kodi menu else.When i enter to "emulationstation" menu, i can't use xbox controller, but if i select a game (with keyboard), xbox controller works in the game..
Other question is :
what keys (from keyboard) are functional in emulationstation menu? (for menu, select, options...)
select, i think it's "ENTER"; and arrows are for move, but if i want to enter at the option menu?
(i've tested all keys without result)I'm expecting your answer.
Meanwhile, I will continue testing configurations.Thanks again escalade !!!
You'll need to bind the controller through the input menu. Key bindings for options are ctrl/alt as described on first page.
I've uploaded new generic build with SABnzbd as well. "systemctl start sabnzbd && systemctl enable sabnzbd"
I'll make some default settings for Transmission so that you won't need to edit settings.json. For the future I'll look at integrating Emby and maybe even Plex Media Player.
Thanks,
I'll see laterPlease
Integrate Sickrage (or Sickbread), Couchpotato, and Headphones instead!!
Then you will have a perfect build!!
XDEnviado desde mi MX_Base mediante Tapatalk
I might do Sonarr
This is EXACTLY what I have been looking for! ES has always been my preferred frontend so think you for all of your work!
Will official PS3 controller and BT dongle work out of the box?
Thanks,
John
If your BT dongle is supported by the kernel, then yes.
If your BT dongle is supported by the kernel, then yes.Sorry...forgot to mention that I am using the generic image (if that matters).
The dongle I have works with Recalbox v3 and v4 out of the box. I'm trying to track down some info on the dongle I purchased. The only markings on it are "CSR V4.0" This is what I see when I do a lsuusb (shown in red) and verbose. Does the fact that the kernel is able to identify it mean it is supported?
Quote
LibreELEC:~ # lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 20a0:0001 Clay Logic
Bus 001 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Display MoreBus 001 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode) Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 224 Wireless bDeviceSubClass 1 Radio Frequency bDeviceProtocol 1 Bluetooth bMaxPacketSize0 64 idVendor 0x0a12 Cambridge Silicon Radio, Ltd idProduct 0x0001 Bluetooth Dongle (HCI mode) bcdDevice 88.91 iManufacturer 0 iProduct 2 CSR8510 A10 iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 177 bNumInterfaces 2 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 100mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 3 bInterfaceClass 224 Wireless bInterfaceSubClass 1 Radio Frequency bInterfaceProtocol 1 Bluetooth iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0010 1x 16 bytes bInterval 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x82 EP 2 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 1 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 224 Wireless bInterfaceSubClass 1 Radio Frequency bInterfaceProtocol 1 Bluetooth iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x03 EP 3 OUT bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0000 1x 0 bytes bInterval 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0000 1x 0 bytes bInterval 1 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 1 bNumEndpoints 2 bInterfaceClass 224 Wireless bInterfaceSubClass 1 Radio Frequency bInterfaceProtocol 1 Bluetooth iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x03 EP 3 OUT bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0009 1x 9 bytes bInterval 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0009 1x 9 bytes bInterval 1 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 2 bNumEndpoints 2 bInterfaceClass 224 Wireless bInterfaceSubClass 1 Radio Frequency bInterfaceProtocol 1 Bluetooth iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x03 EP 3 OUT bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0011 1x 17 bytes bInterval 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0011 1x 17 bytes bInterval 1 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 3 bNumEndpoints 2 bInterfaceClass 224 Wireless bInterfaceSubClass 1 Radio Frequency bInterfaceProtocol 1 Bluetooth iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x03 EP 3 OUT bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0019 1x 25 bytes bInterval 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0019 1x 25 bytes bInterval 1 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 4 bNumEndpoints 2 bInterfaceClass 224 Wireless bInterfaceSubClass 1 Radio Frequency bInterfaceProtocol 1 Bluetooth iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x03 EP 3 OUT bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0021 1x 33 bytes bInterval 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0021 1x 33 bytes bInterval 1 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 5 bNumEndpoints 2 bInterfaceClass 224 Wireless bInterfaceSubClass 1 Radio Frequency bInterfaceProtocol 1 Bluetooth iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x03 EP 3 OUT bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0031 1x 49 bytes bInterval 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0031 1x 49 bytes bInterval 1 can't get device qualifier: Resource temporarily unavailable can't get debug descriptor: Resource temporarily unavailable Device Status: 0x0001 Self Powered
Hi all,
Great setup you have here.
I have setup on pi3 and have all working well using keyboard/ps3 knock off usb controller.
Only problem i see thus far is backing out of emulationstation back to kodi menulikely an easy fix i'm sure i'm missing something.
Thanks again
Deez -
What's the problem? Hit CTRL or whatever button you mapped option to then "QUIT"?
of course.. i did not map anything as of yet.. that explains it
Got my PS3 controllers and tghe CSR BT dongle talking to each other. Just played a little Bubble Bobble!
Thanks for this!
John
