[RK3566] LE for Pine64 Quartz64 Model A
  • OK I have been using the latest nightly build for RK3566 and I've been able to watch videos natively!! I tried playing HDR and SDR videos and all plays smoothly, even 4K. I'm also able to control LE using CEC with my projector's remote control successfully. Thank you!
    I only have some issues at the moment:
    1. When I try to suspend the system, it gets stuck with a loading icon in the middle of the screen and I have to manually reboot. Is this a normal bug of LE or is this related with the nightly releases for the RK chips?
    2. I set LE to not suspend when the projector turns off (because of issue #1) and when I turn my projector off and then on, the CEC no longer works and LE doesn't react to my remote controller.
    3. I installed the Docker add-on and the docker service is not able to start because of an iptables error.
    Error: iptables v1.8.11 (legacy): can't initialize iptables table `nat': Table does not exist...
  • 1. I'll have to ask the upstream kernel maintainers if suspend/resume are supported and expected to work. I won't guarantee it.
    2. In theory the kernel should handle the display device going away and coming back. Kodi only checks things at startup though so might not handle things properly even if things lower in the stack do. In either case the workaround will be (or should be) to run the 'getedid' script so the kernel (and thus Kodi) always sees the display device (via it's EDID data) as connected.
    3. If you are using official nightlies please try the latest image in my testing share and see if that fixes the issue? - I've added some kernel options to make iptables work but can't remember if that change has made it into official nightlies. I'm also unsure if I added all the options for Docker though.
    Thank you for your response!! I'll try the getedid script and hopefully it works.
    For #3, I tried the latest image in your testing share for the Quartz Model A that was uploaded on Oct 19. The docker service is still failing :( Seems to not be able to create the nat chain in iptables, at least is a different error haha
    Oct 29 22:37:37 LibreELEC dockerd[1521]: time="2025-10-29T22:37:37.316172917Z" level=info msg="Loading containers: start."
    Oct 29 22:37:37 LibreELEC dockerd[1521]: time="2025-10-29T22:37:37.548707191Z" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
    Oct 29 22:37:37 LibreELEC dockerd[1521]: time="2025-10-29T22:37:37.551579816Z" level=info msg="stopping h3althch3ck following graceful shutdown" module=libcontainerd
    Oct 29 22:37:37 LibreELEC dockerd[1521]: time="2025-10-29T22:37:37.551939733Z" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
    Oct 29 22:37:38 LibreELEC dockerd[1521]: failed to start daemon: Error initializing network controller: error obtaining controller instance: failed to register "bridge" driver: failed to create NAT chain DOCKER: iptables failed: iptables --wait -t nat -N DOCKER: iptables v1.8.11
    Oct 29 22:37:38 LibreELEC dockerd[1521]: Perhaps iptables or your kernel needs to be upgraded.
    Oct 29 22:37:38 LibreELEC dockerd[1521]:  (exit status 3)
    Oct 29 22:37:38 LibreELEC systemd[1]: service.system.docker.service: Main process exited, code=exited, status=1/FAILURE
    Oct 29 22:37:38 LibreELEC systemd[1]: service.system.docker.service: Failed with result 'exit-code'.
    Oct 29 22:37:38 LibreELEC systemd[1]: Failed to start service.system.docker.service.
    I'm just trying to use LE to also stream music from my turntable (which has a USB cable) by HTTP, but the ffmpeg add-on comes with ALSA disabled and docker is not working. I'll continue to investigate any other way to do this with LE (if it's even possible).
  • There are changes to iptables/nftables in recent kernels and I probably need to spend more time on the issue; which won't happen that quickly as I'm travelling for most of the next week.
    Ok I understand, thank you for taking a look into it!
  • Hello. Just wanted to share some issues I am having with the latest nightly build for the Quartz64 Model A.
    1. I have the 8 GB of RAM version, but LE is indicating that its only detecting around 4GB of RAM in the System Information. Also in the logs I saw this line, so I don't know if this is on purpose:
    [    0.000000] Memory limited to 3838MB
    2. When creating a new profile, the new profile is able to login successfully, but changing back to the master user makes the OS freeze. After that I rebooted and now I'm only able to login to the new profile, if I try to go to the login screen or try to login to the master user, it freezes again.
    I tried watching the logs for any error message, but there is none. Basically logging in to the master user after creating a new profile is impossible. I investigated a little and saw a similar situation during the LE version 10 era, so I don't know of this can be related? That situation was fixed with this commit.
  • LE is indicating that its only detecting around 4GB of RAM in the System Information
    Some of the Rockchip kernel drivers assume 32-bit memory regions (under 4GB) and behave badly when the OS has more, so we currently limit what the kernel can access via mem=3838M in kernel boot params, https://github.com/LibreELEC/Libr…56X/options#L31 to workaround the problems. You can remove the cap and might briefly see 8GB reported, but then it will lock up. LE rarely uses more than 1GB in normal Kodi use so the cap shouldn't be a problem.
  • Ok a workaround I found for the profile creation issue is that I restored a backup from the Kodi app I have installed in my Android TV with the profiles created and now switching between the profiles work. There's probably something wrong in the process of creating a new profile from this version of LE.
    Also when I turn off and then back on my projector, the remote controller no longer works with LE (CEC stops working). I wanted to try to fix it using the getedid script, but the getedid command doesn't seem to exist in this LE. I am trying the latest nightly build. Is there a way I can add or run the script manually? Or is there a possibility to add the getedid command to LE? I just probably need to run the 'getedid create' command to fix this issue.
  • Ok I've been updating constantly to the latest nightly versions and LE has greatly improved it's performance! Now Kodi doesn't crash as easily and everything moves smoother. Thank you!
    Also, so far I've encountered some issues and some of them have been reported and fixed in the past. I don't know if it can be fixed the same way for these rockchips?
    1. CEC stops working after turning the TV back up (there is no getedid command available in this version of LE to fix this, but there was a fix for this in this commit 4 years ago. That patch added in the fix seems to no longer be on the master branch. Other related commit: #5800)
    2. When playing a movie, the video stutters every like 5 to 10 seconds showing a quick image of the next scene. I couldn't find anything in the logs that might indicate the cause of this issue and I don't know if its something that's only happening to me or it's a bug. I am playing the movie from the Jellyfin add-on, but this doesn't happen with another same installation of Kodi I have running on an Android TV.
    3. Creating profiles is possible, but that makes the master user inaccesible and LE crashes when switching back to that user. There was a fix for this in this commit for LE version 10.
  • I've updated the RK356X images (and .tar) in my test share to pick the CEC fixes and include a 'getedid' script. Please test without using getedid and if the issue is solved I will add the patches to the list of things that I can nag Kwiboo about :)
    Not sure about the video stutters, although if that's only in the lastest image (last 24h) it's possibly due to an ffmpeg bump; it would help to see a Kodi debug log to understand config/environment and media. I will dig up a Rock 3C board and experiment in the next couple of days.
    Also no idea on Kodi profiles. The patch you flagged was dropped with the Python 3.9.10 bump aeons back, so if there's an issue it's presumably a new bug as that fix is upstream. You'll need to share a Kodi debug/crashlog for someone to look at.
  • Again, THANK YOU. Haha the CEC now works when I turn my projector back on. And I didn't need to run the getedid command.
    Also, the stuttering went away lol don't know why. I'll stay with your test versions of LE.
    I'll try to test the profile creation again and if it fails I'll send a debug log. I just need a new SD card because I don't want to mess everything I've configured already in this one.
    You're the best!! Thanks again.
