CEC settings not saving on latest LE nightly LE 13
  • Hi, not sure if this is a Kodi issue, a CEC driver issue or an issue with LE.
    However - in testing out my new receiver. I keep trying to change the CEC settings in the input menu to knowing it's connected to the receiver and not the TV.
    The setting seems to stick however when i reset my Intel NUC (w/ Pulse-Eight adapter) it keeps resetting the setting back to 'connected via TV' and my previous setting has been overruled.
    I've still not managed to get CEC working yet via my Denon X1800H despite on Kodi boot i see a Pulse Eight Notification highlighting connected to TV - DenonX1800 but i'm thinking that this issue is currently happening because of the setting problems.
    This too happens on the LE 12 branch too.
    Any help is much appreciated.
  • You can try to reset to defaults settings first for the CEC Adapter, then set what you want to set.
    I have strange bevahior since the new libCEC 7.0.0. If I disable CEC, when I try to re-enable it, it stays disabled
    The reset fix that (but I need to modify again all the annoying auto on/off settings 😁)
  • That looks like the one!
    Just to highlight for anyone else who's wanting to fix this. I managed to fix by removing the Universal Remote settings from the AVR in my LG G4 - Weird but now the remote controls everything its great.
