If you r watching a manga without forced subtitles it will show normal subtitles depending on the language chosen in the subtitles settings page...if forced subtitles exist they will be shown first
Subtitle Setup for a Specific Language
Albert -
March 23, 2025 at 9:14 PM -
No, For the original version with subtitles, the subtitles are full only. There are no forced subtitles in the original version with subtitles.
Sorry I m lost now..
In that case the original subtitles are shown...
I don't know what to do
Hi,
I still haven't found a solution to this problem.
You could upload a sample clip including subtitles.
I had opposite problem with subtitles, always wanted to have original audio but specific subtitles language plus ignore forced subtitles if exists - ended up with creating my own little plugin for this
Anyways, if current (updated) settings in Kodi aren't working for you, you can install Language Preference Manager plugin, which has zillion of options so some settings here should fix your problem. -
What do you mean ? It does it to me on every video.
Anyways, if current (updated) settings in Kodi aren't working for you, you can install Language Preference Manager plugin, which has zillion of options so some settings here should fix your problem.it's an old addon, It worked well before
Anyways, this is how it works currently:
[VideoPlayer] Fix and improve subtitle stream selection by CastagnaIT · Pull Request #25813 · xbmc/xbmcDescription i started rework this part, starting from impaired problems and then i improved also other use cases problems fixed: if you set…github.com -
