[x86-64] Stuck on Splash installing LE 13 Nightly (Generic) on HP T620
    after successfully installing newest LE13 nightly on my HP T630 i also wanted to install it in my cellar on HP T620.
    Boot screen hangs but system seems to run in background.
    Can not connect via SSH.
    But i can browse the diretories with a Windows Client.
    Installing LE12 does not have this problem
    ZIP-File attached for LE13 and LE12 after install and reboot
    I am a windows guy and have not much knowledge with linux ...
    Any help appreciated ...
    EDIT :
    I removed "quiet" and added "textmode" to the RUN-command on the USB-stick (found in other thread)
    The result you can see on the screen-photo attached
  • Code
    Feb 28 16:21:02 LibreELEC kodi.sh[1025]: ERROR: Unable to create GUI. Exiting
    Something is wrong between mesa and the GPU so there's no DRM/OpenGLES surface for Kodi to render the UI into, so nothing overwrites the boot splash, thus giving the appearance of a boot hang, although that's almost never true.
    See if the Generic Legacy (which uses X11 not GBM) works any better.
    yes, tried LE13 Generic Legacy but also does not work.
    Only black screen with a visible mouse pointer is there ....
    I will try your suggestion with "amdgpu"
  • Adding these parameters to the syslinux.cfg did not solve the problem.
    I did not even get the Libreelec splash screen ... kernel loaded - ok ... and then nothing happens further ...
    I am thinking now of buying a HP T730, which i did not test so far ....
