[Strong SRT2400] AP6212 WiFi Issue
  • 1. Doesn't work WIFI module, as in previous LE versions (16.x to 17.x). According to MAC Address range: 44:2C:05:00:00:00 - 44:2C:05:FF:FF:FF, vendor is "AMPAK". I tried to run LE with different device trees, working without WIFI support was: gxbb_p200_1G_100M.dtb, gxbb_p200_1G_100M_RealtekWiFi.dtb, gxbb_p200_1G_wetek_hub.dtb, gxbb_p200_k1_plus.dtb. But WIFI work on LE13 with "meson-gxbb-nexbox-a95x.dtb" device tree.
    2. Properly working software deinterlace on SD resolutions was from 16.x to 17.x versions, but from 18.x version it work with frame dropping.
    3. From 18.x version doesn't work OK button, but it fixed with this solution manually: RE: Ok button doesn't work on H1 remote
    You have written a lot of things, but there is not much meaningful information in it.
    What box do you have? And specifically, what kind of WiFi chip is in your box?
    If you could send me a log, both from the previous working and the currently non-working versions, I might be able to help.
  • The Nexbox A95 device-tree file in the upstream kernel defines no SDIO WiFi module, which normally means the module will not be probed and detected. It's possible the module is connected via USB instead; it's nnot unheard of but unusual in Amlogic boxes of that era. Ampak modules are normally using Broadcom chipsets, but which one? Logs from the Android/vendor kernel are needed else there are more questions than answers.
  • I don't know, but vendor determined by MAC is "AMPAK".
    That's why it would be good to have the relevant part of a kernel log from a previous working system.
    For example: dmesg | grep dhd
    (If it's really Ampak, which is actually an SDIO wifi+bt combo adapter based on Broadcom chips.)
  • That's why it would be good to have the relevant part of a kernel log from a previous working system.
    Log from this 9.2 build, without working WIFI. Can it help? I have no way to run working LE 13 build now.
    dmesg | grep dhd
    [ 11.049187@2] dhd_module_init: in
    [ 11.049222@2] dhd_wifi_platform_load: Enter
    [ 11.792953@2] dhdsdio_probe : no mutex held. set lock
    [ 11.878301@2] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=0
    [ 11.878336@2] dhd_conf_set_conf_path_by_nv_path: config_path=/usr/lib/firmware/brcm/config.txt
    [ 11.878513@2] dhd_os_open_image: /usr/lib/firmware/brcm/config.txt (399 bytes) open success
    [ 11.909689@2] dhd_conf_read_nv_by_chip: nv_by_chip_count=12
    [ 11.909702@2] dhd_conf_read_nv_by_chip: chip=0xa962, chiprev=0, name=nvram_ap6181.txt
    [ 11.909706@2] dhd_conf_read_nv_by_chip: chip=0xa962, chiprev=1, name=nvram_ap6210.txt
    [ 11.909710@2] dhd_conf_read_nv_by_chip: chip=0xa9a6, chiprev=0, name=nvram_ap6212.txt
    [ 11.909714@2] dhd_conf_read_nv_by_chip: chip=0xa9a6, chiprev=1, name=nvram_ap6212a.txt
    [ 11.909718@2] dhd_conf_read_nv_by_chip: chip=0x4345, chiprev=6, name=nvram_ap6255.txt
    [ 11.909722@2] dhd_conf_read_nv_by_chip: chip=0x4330, chiprev=4, name=nvram_ap6330.txt
    [ 11.909726@2] dhd_conf_read_nv_by_chip: chip=0x4339, chiprev=1, name=nvram_ap6335.txt
    [ 11.909730@2] dhd_conf_read_nv_by_chip: chip=0x4354, chiprev=2, name=nvram_ap6356.txt
    [ 11.909740@2] dhd_conf_read_nv_by_chip: chip=0x4335, chiprev=1, name=nvram_bcm4335.txt
    [ 11.909753@2] dhd_conf_read_nv_by_chip: chip=0xa94c, chiprev=2, name=nvram_ap6234.txt
    [ 11.909758@2] dhd_conf_read_nv_by_chip: chip=0x4359, chiprev=9, name=nvram_ap6359sa.txt
    [ 11.909762@2] dhd_conf_read_nv_by_chip: chip=0x4334, chiprev=3, name=nvram_bcm4334.txt
    [ 11.909821@2] dhd_conf_read_config: mimo_bw_cap = 1
    [ 11.910138@2] dhd_conf_read_config: bcn_timeout = 20
    [ 11.910258@2] dhd_conf_read_config: kso_enable = 0
    [ 11.910576@2] dhd_conf_read_config: PM = 0
    [ 11.911775@3] dhd_attach(): thread:dhd_watchdog_thread:af0 started
    [ 11.911802@3] dhd_attach(): thread:dhd_dpc:af1 started
    [ 11.911830@3] dhd_attach(): thread:dhd_rxf:af2 started
    [ 11.911839@3] dhd_deferred_work_init: work queue initialized
    [ 12.209740@2] dhd_open: WLAN driver is not initialized
    [ 12.209857@2] dhd_wl_ioctl: returning as busstate=0
    [ 12.210445@2] dhd_txglom_enable: enable 0
    [ 12.210449@2] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
    [ 12.210452@2] dhd_conf_set_txglom_params: txglom_bucket_size=0
    [ 12.210456@2] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
    [ 12.210460@2] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0
    [ 12.210469@2] dhd_bus_devreset: WLAN OFF DONE
    [ 12.211549@2] dhdsdio_probe : the lock is released.
    [ 12.211738@2] dhd_module_init: Exit err=0
    [ 13.216570@2] dhd_open: Enter ffffffc0238e9000
    [ 16.077307@2] dhd_open : wl_android_wifi_on failed (-110)
    [ 16.077359@2] dhd_stop: Enter ffffffc0238e9000
    [ 16.077583@2] dhd_wl_ioctl: returning as busstate=0
    [ 16.077660@2] dhd_net_bus_devreset: dhd_bus_devreset: -35
    [ 16.277041@2] dhd_stop: Exit
    [ 16.277333@2] dhd_open: Exit ret=-1
    chip:0xa9a6. It looks like AP6236?
    Edited 3 times, last by Lirk (November 25, 2024 at 3:29 PM).
  • Based on the log, reinitialization of the SDIO bus fails, but I don't really understand why.
    Was this a clean install? Because based on the amount of installed addons, I wouldn't guess that.
    If you have upgraded from a previous system or restored a backup from an older system, I would definitely recommend performing a clean installation. Also, if the dtb you are using comes from an external source, that could also be a reason. Only use dtbs from the device_trees directory.
  • Was this a clean install?
    Yes.
    I think that problem gone in new releases with some fixes in new kernels 5.x/6.x.
    So, about software deinterlace problem... In LE 16.5/17.6 releases software deinterlace worked properly with doubling framerate. But from version 18.x deinterlace works poor with frame dropping. Hardware deinterlace works properly, but videos a little blurry with it in comparison with software deinterlace.
    Just compare playback this interlaced video: https://samples.ffmpeg.org/MPEG2/interlaced/burosch1.mpg in version 17.6 and in 18.9 with disabled hardware acceleration.
    Edited once, last by Lirk: Merged a post created by Lirk into this post. (November 26, 2024 at 4:27 PM).
  • Lirk As mentioned by chewitt , no more support for you under current conditions.
    If you still have questions, open a new thread, and provide a clean log.
    newphreak
    March 15, 2016 at 1:02 AM
