Do you have a firmware i can look at?
Demetris -
December 7, 2016 at 10:38 PM -
Thread is Resolved
Hi can someone help, I have Tronsmart s89 with openelec I would like to migrate to LE Krypton. Will this image work for my box, if so kindling supply a link to the tar file.
Thanks for your supports.
Of course it will you can find download links in OP
Do you have a firmware i can look at?The MyGica official OpenELEC (devel-20160128164651-r21691-g6105ca2) can be downloaded from here. Does that help? Anything else I can provide?
Thanks!
I need an official android rom not a custom made openelec image
I need an official android rom not a custom made openelec imageOk, would this work?
This package is older but includes everything.
Is that any help?
Of course it will you can find download links in OPHi Demetris, What do you mean by OP, I am new to this forum, here is what I found "https://www.androidfilehost.com/?fid=673368273298930809" would that be the link and the latest Krypton image for S89 Tronsmart?
Cheers!
OP = Original post, so first post that you see on page 1 of this thread: thread-2877.html
OP = Original post, so first post that you see on page 1 of this thread: thread-2877.htmlI got it, Post #1
Thanks -
Of course it will you can find download links in OPThanks all A-lot this works like a charm , great work! hope so see the latest release soon.
Cheers!
Hello Demetris!
I have a request for you if you don't mind: Could you build the LE-8.0-RC2 ROM, also for the MINIX NEO X8-H PLUS?Here are the details of this box:
CPU: AMLogic S812H (8726_M8)
GPU: Mali-450
RAM: 2GB
eMMC: 16GB
Enthernet: GigabitAnd here is a link to the latest official firmware: Official X8-H PLUS 011 firmware (20170119) | MINIX Forum - Official
If needed, I can provide logs from serial console for debugging. Thanks!
@Iparker
Download me from here the atv-380 firmware and upload it for me:
ATV 582 / ATV 380 - MyGica Support Forum
Note that if you have the 582 i cant help you because that one looks like is not an S802 -
@Iparker
Note that if you have the 582 i cant help you because that one looks like is not an S802Here's the ATV380 factory firmware uploaded to my drive:
ATV380_Factory_Files.zip - Google DriveThanks again Demetris
your board file is called stvm8_dongle_1ga and stvm8m2_tongfang_2gpmu, looks like there is no reference in the kernel about it, sorry
You can try the 1GB edition and see if it boots for you -
No spdif audio using s82 img for minix neo x8h can this be added please? Another bug what i found when i turn off the minix device libreelec shutdown but the device doesnt shut down. I hope this can be fixed also. But videoplayback and performance is great thx
did you went through the different audio out options?
Cant do anything about your device as i don't have it and is not officially supported by me, feel very lucky that it boots on you
What image you tested? -
What image you tested?I tested s82 image because the most specs are the same. There is a openelec 6.0.3. Img for minix devices is it possible to use that one to recompile your LibreELEC version?
If they have source code released of cource , would be very easy to add your device
