  • Anyone running Gamestarter Addons with the new RPi 4?Is it working OK?
    I have installed retroarch, but it crashes on startup and just restart kodi. So I guess an update is required to get it to work.
  • I have installed retroarch, but it crashes on startup and just restart kodi. So I guess an update is required to get it to work.
    If you are using LE 9.1.001 onwards you need to download the 2 libass files from here and it should work normally...at least on Rpi2 and 3..I assume it's the same for 4..
  • Don't work with LibreElec 9.80 test build (ARM) from Index of /
    Gamestarter Install is OK, but reboot when launch RetroArch or EmulationStation.
    libass add change nothing...
  • Gamestarter Install is OK, but reboot when launch RetroArch or EmulationStation.
    Install LibreELEC-Generic.x86_64-9.1.002
    Any help?
  • There shouldn't be any issues...all is working fine..
    Did you add both files to the folder?
    1. /storage/.kodi/addons/game.retroarch/lib
    If you did better you post some logs...mainly
    1. /storage/.kodi/temp/retroarch.log
    and
    1. /storage/.kodi/temp/retroarch_debug.log
  • Added libssl and libcrypto, still hitting a snag.
    I don't think Gamestarter is yet updated to work properly with latest Rpi4 and LE 9.1.....
    It does work with LE 9.1 with some tweaks with RPi 2 & 3.
    Maybe in the meantime you can try this with Rpi 4
