Has any one had issues with WiFi on Raspberry Pi 3. I install LibreELEC through NOOBS and when you first go through the initial setup you can join the Wifi network with out any issues. If you then try to join another WiFi network after it seems to never work. All that happens is in the bottom right hand corner an error message pops up and and says "invalid argument". If I then hard reset LibreELEC I can then join a WiFi network again. This has happened on multiple Pi with the exact same result.
The same is also true if you set up on Ethernet first and then try to join a Wifi network afterwords, the same error message appears.
Is this just me?
