LibreELEC (Omega) 12 Beta1
Thank you for the new release. I just downloaded it and I am testing it now.
As it seems, it still has the same issue with wifi that le 11 had, because iwd and connman could not work well together. Instead of rebooting until it works, which is what I did on le 11, this time I tried disabling and re-enabling it from le settings. The first time it started after 2 or 3 tries. This time I have already tried 9 or 10, but it still does not come up, so I connected via ethernet to ssh to it, get logs etc.
So, what should I include on the new thread I am about to open?
If this is about your ageing Amlogic box? the primary issue is the unmaintained Realtek vendor drivers it requires that are not fully conformant to modern kernel wireless frameworks, so no point/need to start threads on them. If you're lucky I might be able to persuade the person working on upstream support for RTL8192DU to look at RTL8189ES/FS in the mid-term future.
The download links for Pi 4 and 5 give a 404 because the URL still says "arm" instead of "aarch64", but once I found the correct link, the build for Pi 4 seemed to work fine. I had to manually install a couple of the LibreELEC add-ons, namely InputStream Adaptive and Network Tools, because the compatible versions don't come up in the repository yet, but that's pretty expected with a beta.
No, it is about x64, the generic-legacy img and my old laptop. Sorry for not mentioning it.
The le 11 issue with wifi is/was platform independant though. I faced it on the nightlies of le 11 from May to September of 2022 on my rpi3b+, until I gave up completely on le there.
Oops .. should be fixed in https://github.com/LibreELEC/website/pull/19
LE12 definitely seems to work better on my Allwinner H6 box, especially for HDR content.
Stupid noob question but how do I reinstall Widevine after upgrading from 11.06
Open the inputstreamhelper addon and choose reinstall.
Thank you Hias, Netflix is happy again!
Just for anyone else that has to RTFM open the Inputstream Helper addon and select Settings, under Expert choose (Re)install Widevine CDM library...
Cheers
David
Anything done for AMD 4x00G 5x00G support?
I am still on legacy with my AMD boxes cause h265 and xvid are still sound only @11.06
THX for your effort! -
likewise the situation has improved, no idea if it just works now as nobody from the team has a similar setup
THX for your effort!This is the only AMD update that I’m aware of - https://github.com/LibreELEC/LibreELEC.tv/issues/8208 (so will need a test on your system)
No comment on the hardware, configuration, or media type so nothing to investigate.
Raspi 4 now on Omega b1. Appears great and very stable. Many thanks!
Have been on the nightlies for a long time with very few issues so no surprise really.
The only issue i am still seeing is that sometimes HDR does not work after boot. A reboot fixes that, 100% repeatable.
Have tried delaying the start of the Raspi a while after the AVR but does not help so far. No biggie but reported FWIW.
Edit: some minor tweaks to the boot sequence in Home Assistant appears to have fixed it. So unlikely a LE issue.
Have you tried using get_edid create?
Thanks! Might look into that if issue persists, was not aware of it.
Also did not have these issues before Omega.It is by no means a biggie though to do a reboot also. Will experiment with other timings also.
Many thanks!
