It appears I've learned a new copy/paste skill
Can you run "pastekodi" so I get the whole log.
Official LE12 Test Images for Amlogic (Kodi-21)
chewitt -
September 4, 2023 at 6:15 PM -
Thread is marked as Resolved.
dmladenov update and registers again please: https://chewitt.libreelec.tv/testing/LibreE…h64-11.95.2.tar - the register poking has been finessed by MartinB who's far more competent at this coding lark
https://paste.libreelec.tv/super-hermit.log
The audio is OK. -
Thanks, we need to see if we can discover the right names for the registers we're poking (even the vendor kernel is vague on this) and then we'll send changes upstream.
LibreELEC-AMLGX.aarch64-12.0.0-wetek-play2.img inside a Minix Neo U1.
Set extlinux.conf to: "meson-gxbb-p201.dtb"
No run.
Why?
The Wetek Play 2 dtb also no boot.
Just stuck at the boot logo:
EDIT: LibreELEC-AMLGX.aarch64-12.0-nightly-20240406-4b7642d-wetek-play2.img Also ... ... NO ... BOOT
S*** Linux ... Minix Neo u1. very rare, unknown box ROFL.
I give it up ... Back to good old super duper 9.0.1 WITH working Sync Playback 2 Display.
EDIT2:
One last try ... This time with LibreELEC-AMLGX.aarch64-11.95.1-box.img @ meson-gxbb-p201.dtb
AAAAAAAAAAAAnd of course ... Computer says ... ... No!
LibreELEC-AMLGX.aarch64-12.0.0-wetek-play2.img inside a Minix Neo U1.Set extlinux.conf to: "meson-gxbb-p201.dtb"
No run. Why?
This image is design to boot WP2 boxes from emmc (or SD with emmc erased). It will not boot anything else (as you discovered).
This is the correct image to use with devices with vendor u-boot. The initial boot is successful and then when the device reboots after resizing this sometimes happens; and I have no idea why. All you can do is repeat the install process until it works. You might need to check and repair (fsck) the filesystems on the SD card.
ok ... sry ... im a lil but angry, especially about the deinterlacing of the pi4
LibreELEC-AMLGX.aarch64-12.0-nightly-20240412-48fc90e-box.img with "wetek play 2 dtb" works on my u1. (with gxbb-p201 i have no lan and usb storage)
But with sdcard inside the sdcardslot of the box i always get the "error in mount_flash".
sdcard inside a sdcard to usb converter works.
the "FPS_test_1080p23.976_L4.1.mkv" plays some seconds and then hangs with buffer symbol with enabled prime decoder. playing stuff without hardware acceleration us useless.
some other h264 ran fine AAAAND... "SYNC PLAYBACK 2 DISPLAY" works again.
23.976p plays at 104.271% to speedup to 25fps
"Stats" say that "missed" is running up but video runs smooth.
these are my 1st results.
I'd guess the SD card is a newer/faster one and doesn't get reset properly after the initial boot and thus can't be read-from. If you find an old/slow SD card without fancy fast modes it will probably work. Using the USB adaptor sidesteps such issues.
NB: AMLGX is not perfect. If you want to nit-pick on what works/doesn't, you can save fingers from typing forum reports about this/that test file because a) I know there are bugs, b) I know nobody is working to fix them. I'd like to see improvements of course, but until there are some, the reports aren't interesting. Best results come with using the mode whitelist and adjust-refresh. Using "sync playback to display" will probably cause more issues that it might solve. If it works for you, that's nice. If it doesn't,
yep
chewitt Are there any changes in video decoding in your latest compilation with kernel 6.9.0-rc5? It seems to me that it works more stable with hardware decoding enabled for 4K video. Is it better to use Direct to Plane or EGL?
I am using a Tv Box with Amlogic S912.
This experimental change was added: https://github.com/chewitt/linux/…ebdc0f2c772d153 and there's a fix for VP9 @ 59.94 (already merged upstream) but otherwise no changes. What kind of media are you playing?
Direct to Plane should be used always.
I usually don't watch 4K and have hardware decoding turned off. But occasionally something will hit, or I test myself short demos in 4K and HDR, or without HDR. These are mostly h246 and h265 but vp9 also happens. It seemed to me that lately the scrolling works a little better with hardware decoding enabled.
Moments after writing the previous post, unfortunately the whole system crashed. This happens as you switch between videos with different codecs, and as far as I know this is a known problem.Is there still any hope that someday it will work better on the S912?
Of course I don't expect anything, I'm just asking out of curiosity.
By the way, thank you for your work. -
There are issues in the codec drivers that cause memory (buffer) starvation. Repeated plays using the same codec eventually hit the problem. Swapping between codecs seems to cause them faster. It's nothing specific to S912 and impacts all chips.
I'm told LibreComputer plan further work on the codecs (resuming where last years effort/funding stopped) but that all depends on sales revenues to provide funding, info from Amlogic, and availability of commercial developer resources. It's a large piece of work to line up, so no breath holding.
Just tested the Latest Stable Version (2024.05) - https://releases.libreelec.tv/LibreELEC-AMLG….0.0-box.img.gz
The device tree meson-gxl-s905l-p271.dtb is there. The audio is OK.
Everything else is as with your images. -
