  • now i answer myself, i hope everyone can help with this following issues (after sleeping now 5 hours experinces,,,):
    --------i have a complete great working box "KII Pro", i need to clone this box 1:1------
    on the box works 8.0.2c-I
    i download LibreELEC-S905.arm-8.0-8.0.2c-I.img.gz
    put it on my SD card (rufus) , download gxbb_p200_k2_pro.dtb and replace it to dtb.img
    libreelec starts, checking/resize storage and reboot, kodi picture starts, the screen goes black and the box shut down (green LED goes Red)
    i can start the box new, libreelec/kodi comes, (only the kodi 17.3 Picture) but the box goes shutdown!
    When i start this SD card on my working kodi box, a new Kodi starts! with default settings!
    Ok, the box is damaged? I have more then one, new Box packed out and start again! The same one, libreelec starts, kodi pictures start, black screen, box goes shutdown itself.
    Ok, i see from @sinancetinkaya the Image
    LibreELEC-S905.arm-8.2-devel-201710231024-gd562e8e-I.img.gz
    i burn it on SD, put right dtb on the SD....starts again on a new Box, that Kodi works! but i cannot use my old settings from 8.0.2c-I, something dont works, and i see i dont have a Lan Port, only WLAN works. I must have LAN. Anyone have a Idea why only WLAN works on this Version?
    i have tested a Version wirth 8.9-k, works too, but Kodi 18, and then i must do complete new all addons.
    Can anyone help me with my issues?
  • UPDATE:
    i found my failure! I have KII Box with S905D inside!!!
    i will test now S905D Images
    See pics
    I have to create new dtb.img for you.
    Pls, send me from android dtb.img. Boot LE from SD card , connect via ssh and submit command dd if=/dev/dtb bs=256k count=1 of=/storage/backup/KII_proD.dtb
    Send me file from /storage/backup or Samba share \\<box-ip-address>\Backup.
  • franky644 Are you sure this is a device tree from K2 Pro that has Android on internal memory? This looks 100% like K1 Pro device tree for LE.
    your´re right, thats LE, now i understand what afl1 need, sorry, i´m new !
    I must read how can i emable ssh on android, then comes the dtb, im must now to my work
  • i´m now not at home, i will have a look tomorrow in the morning. on my table 3 boxes at the moment, one have LE internal.
    I will test tomorrow with a complete new box, start with toothpick LE from SD, the go with ssh and put the command.
    thats right!?
  • äi will check it, thx a lot!
    after reading the specs on alibaba/aliexpress/ etc pp, i dont check the real differences from Ki plus/pro and new Kii pro
    The most difference i think is DDR III and DDRIV RAM, right? i will check of new KII have a 100 or 1000 LAN
    I search for new buying the best for our Experience with DVB included (please with DVB-C)
  • humm the LAN Speed ist 100....
    [ 17.047820@1] libphy: stmmac-0:08 - Link is Up - 100/Full
    the first check say all is ok, i can boot a normal Image. @ AFL great work.
    Can you help me for the Tvheadend and DVB-C issue? My Brother have german Unitymedia, What must i do?
    I think the best buy is KI Pro. For tvhheadend setup watch tutorials on youtube.
  • Update: I use the LE 8.0.2c-I image on a new Box (S905D) , start backup from my old S905 (without "D") start Restore and installtointernal, Job finished .
    After a restart without Card comes libreelec Screen, on the left side top, and comes
    LibreELEC Community Version 8.0.2c-I
    ..and nothing else, no boot from internal. i use my Backup from the old S905 K2 (S905 without"D")
    is it possible that have the Backup wrong dtb or others Informations from old 905 useinside?
  • guys, this hobby is very strange!
    its very hard to find out for Beginners without Support where are the problems.
    After Reading the Forum (10 hours or so...) i find one from @afl,
    i put this gxl_p231_2g_dvb.dtb in the archiv, and make the steps, and now i can make installtointernal, and it runs!
    You have to start with reading sticky threads to save time.
