I use a KII Pro as server connected with ethernet cable and the streaming of SD and HD contest inside home (both wifi and lan) work perfectly. It works very well also with tvhclient on Android phone.Inviato dal mio LG-D802 utilizzando Tapatalk
What is your client, with what software (version too)?
All setting is default, or you change something?
gigabit or 100mega lan?
I use gigabit mini MX with le 7.0.2 Kodi 16.1 with gigabit lan, and with the default tvh client software from repo.
i tried from pc too, with kodi 16.1 windows. There is mostly good the vq.
@afl with kodi 16.1 and minimx the max vq is only 10, when I switch to channel.
It is matter use your tvh client version?
I will try le 8beta6 on sd
