Me too. Still on 108 version.
afl1 -
November 29, 2016 at 9:04 PM -
AGAIN!!!
Please, double check your installation! Upgrade addons from LibreELEC repository to the latest version.
I tested tvheadend 8.1.109 (4.1.2415) + oscam 8.1.103 (11350).My builds strictly are following kszaq's builds adding only internal driver. Now I am testing vesion with public internal driver fully compatible with latest kszaq's build. I'll publish this version with full source code.
You have mentioned previously that the internal driver is closed source. Something has changed since then?. -
So with new version 8.1.109 scan is stuck, with old version scan ok, but no playback paytv. TV without encryption played. Something stucked between oscam and tvh
tvh log:017-02-01 16:43:56.653 subscription: 0056: "127.0.0.1 [ admin | Kodi Media Center ]" unsubscribing from "RTL+", hostname="127.0.0.1", username="admin", client="Kodi Media Center"2017-02-01 16:43:56.655 mpegts: 12034.36V in Thor - tuning on Availink AVL6862 : DVB-S #02017-02-01 16:43:56.679 capmt: Oscam: Starting CAPMT server for service "RTL Klub HD" on adapter 02017-02-01 16:43:56.680 subscription: 0059: "127.0.0.1 [ admin | Kodi Media Center ]" subscribing on channel "RTL Klub HD", weight: 150, adapter: "Availink AVL6862 : DVB-S #0", network: "Thor", mux: "12034.36V", provider: "UPC Direct", service: "RTL Klub HD", profile="htsp", hostname="127.0.0.1", username="admin", client="Kodi Media Center"2017-02-01 16:44:04.772 http: 192.168.1.25: HTTP/1.1 POST /api/mpegts/input/network_list -- 4002017-02-01 16:44:04.772 http: 192.168.1.25: HTTP/1.1 POST /api/mpegts/input/network_list -- 4002017-02-01 16:44:05.742 TS: Thor/12034.36V/RTL Klub HD: H264 @ #251 Continuity counter error (total 1)2017-02-01 16:44:05.904 http: 192.168.1.25: HTTP/1.1 POST /api/mpegts/input/network_list -- 4002017-02-01 16:44:05.908 http: 192.168.1.25: HTTP/1.1 POST /api/mpegts/input/network_list -- 4002017-02-01 16:44:15.824 TS: Thor/12034.36V/RTL Klub HD: H264 @ #251 Continuity counter error (total 10)2017-02-01 16:44:25.993 TS: Thor/12034.36V/RTL Klub HD: H264 @ #251 Continuity counter error (total 15)oscam log- 2017/02/01 16:46:46 4893BA3A c (dvbapi) Demuxer 1 no suitable readers found that can be used for decoding!
- 2017/02/01 16:46:46 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 0 CAID 1880 PROVID 000000 ECMPID 1954 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:46:49 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 3 CAID 0D97 PROVID 000000 ECMPID 1760 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:46:52 4893BA3A c (dvbapi) Demuxer 1 restarting decodingrequests after 1 ms with 2 enabled and 4 disabled ecmpids!
- 2017/02/01 16:46:52 4893BA3A c (dvbapi) Demuxer 1 no suitable readers found that can be used for decoding!
- 2017/02/01 16:46:53 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 0 CAID 1880 PROVID 000000 ECMPID 1954 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:46:56 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 3 CAID 0D97 PROVID 000000 ECMPID 1760 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:46:59 4893BA3A c (dvbapi) Demuxer 1 restarting decodingrequests after 0 ms with 2 enabled and 4 disabled ecmpids!
- 2017/02/01 16:46:59 4893BA3A c (dvbapi) Demuxer 1 no suitable readers found that can be used for decoding!
- 2017/02/01 16:46:59 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 0 CAID 1880 PROVID 000000 ECMPID 1954 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:47:02 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 3 CAID 0D97 PROVID 000000 ECMPID 1760 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:47:05 4893BA3A c (dvbapi) Demuxer 1 restarting decodingrequests after 1 ms with 2 enabled and 4 disabled ecmpids!
- 2017/02/01 16:47:05 4893BA3A c (dvbapi) Demuxer 1 no suitable readers found that can be used for decoding!
- 2017/02/01 16:47:06 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 0 CAID 1880 PROVID 000000 ECMPID 1954 ANY CHID PMTPID 0000 VPID 00FB
- 2017/02/01 16:47:09 4893BA3A c (dvbapi) Demuxer 1 trying to descramble PID 3 CAID 0D97 PROVID 000000 ECMPID 1760 ANY CHID PMTPID 0000 VPID 00F
and with the same settings ( i checked many times, and later try copied oscam from userdata/addondata folder from my wetek) with my wetek play it worked without problems
With wetek play:
- dvbapi) Demuxer 0 ecmpid 0 CAID: 0653 ECM_PID: 1868 PROVID: 000000
- 2017/02/01 19:00:46 3ADBD4DD c (dvbapi) Demuxer 0 ecmpid 1 CAID: 0D97 ECM_PID: 173C PROVID: 000000
- 2017/02/01 19:00:46 3ADBD4DD c (dvbapi) Demuxer 0 ecmpid 2 CAID: 0B02 ECM_PID: 14E4 PROVID: 000000
- 2017/02/01 19:00:46 3ADBD4DD c (dvbapi) Demuxer 0 ecmpid 3 CAID: 1815 ECM_PID: 13B8 PROVID: 000000
- 2017/02/01 19:00:46 3ADBD4DD c (dvbapi) Demuxer 0 found 4 ECMpids and 1 STREAMpids in caPMT
- 2017/02/01 19:00:46 3ADBD4DD c (dvbapi) Demuxer 0 found channel in cache and matching prio -> start descrambling ecmpid 1
- 2017/02/01 19:00:46 3ADBD4DD c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0D97 PROVID 000000 ECMPID 173C ANY CHID PMTPID 0000 VPID 01C3
- 2017/02/01 19:00:47 3ADBD4DD c (dvbapi) Demuxer 0 found 4 ECMpids and 2 STREAMpids in PMT
- 2017/02/01 19:00:47 3ADBD4DD c (ecm) anonymous (0D97@000004/0000/7664/B8:0E204470B0CC76B8DDC0057DC6CF88EB): found (339 ms)
work flawlesslySomething problem is with tuner driver or tvheadend.
I guess tuner driver problem, because with dvb-t stick work encrypted stream, only with dvb-s not.
Without encryption work the dvb-s tuner, so i think something is here with pid's lost with tuner.With wetek play and libreelec 7.0.3 with the same settings work everything.
tvheadend 4.2 7.0.102 4.1.1945
oscam 7.0.101"Demuxer 1 no suitable readers found that can be used for decoding!" that important information for you, oscam setting! or version
afl1 any idea when and if, fix for non working usb port will be released?
Hi frinds
im trying to install the lastest version LibreELEC-S905.arm-8.0-devel-7.90.beta3-20170124084432.img.gz on K2PLUS and use the dtb.img for k2 plus buts its imposible to boot.
I have used dd and libreelec sd creator, but it is imposible to boot, after resize de sd , the screem show
can not mount /dev/SYSTEM.could anybody help me?
sorry for my englishThxs
Hi frinds
Try installing an android version that is unlocked, for example: a25D7wiW342DxE
Then try installing this LibreELEC -
Now works!! . Thxs. -
I have good reader.
with the same settings wetek play works.
The difference :wetek play use Demuxer 0
maybe oscam cannot work with Demuxer 1? -
I have good reader.
I have the identical problem. With fresh install of tvheadend all work ok (dvb-s internal ok, dvb-t int disabled, external dvb-t ok).
After I remove the external USB dvb-t and manage to add iptv inside tvh. After this demuxer 1... Also with dvb-s disabled the internal dvb-t demuxer 1. If I reconnect external tuner and disable internal, tvh return to work also for crypted ch.
In this days I'll try with tvh 109Inviato dal mio LG-D802 utilizzando Tapatalk
Bluetooth should work? For my kii pro is set on disabled, there is a way to enable it?. Thanks in advance.
Go to the "service" in LibreELEC setting, then at the bottom of it, you have to enable bluetooth there.
Thanks.Sent from my Redmi Note 3 using Tapatalk
I got it working now!I had to instal actual original android firmware to flash first.
I can now run your build from SD without "ssh :can't access tty : job control turned off" issue.
Maybe this has some thing to do with the version of recovery.
afl1
You should write this to the instructions on first page.Hello
I used this method for use 8.0 version, and now nothing boot from SD. What´s happen?
Please, help me. Thank you.
I tried with tvh 109 but internal dvb-t is missing (only dvb-s is available) and the external USB dvb-t fail to scan channel. DVB-T work only with tvh 108...Inviato dal mio LG-D802 utilizzando Tapatalk
Update in #1.
This version is very experimental as I am not fully happy with kszaq's porting amlogic v4l2 driver to media_build. You can remember knowing tvheadend42 issue after this porting. In my testing this release I found issue after switching channel sometimes playback remain in stuck. Resume playback is possible only rebooting box or trying play video from HD.
New version has experimental support for DVB-C. I had never tested it as I have no dvb-c.
I am porting avl6882 driver from crazzycat media_build to be able publish complete sources for internal dvb driver.
For now only dvb-t part of driver is running. For dvb-s diseqc is running but something is wrong in demod initialization.
Also I found some bugs in amlogic demuxer implementation, e.g. small section filters are buggy and can cause serious problems in channel scanning. -
afl1 If you want to use media_build, you have to port Amlvideo driver into it. What issues have you found? Any solutions you can suggest?
afl1 If you want to use media_build, you have to port Amlvideo driver into it. What issues have you found? Any solutions you can suggest?For loading amlvideo module in boot log is following error message:
Display More[ 5.845598@3] WARNING: You are using an experimental version of the media stack. [ 5.845598@3] As the driver is backported to an older kernel, it doesn't offer [ 5.845598@3] enough quality for its usage in production. [ 5.845598@3] Use it with care. [ 5.845598@3] Latest git patches (needed if you report a bug to linux-media@vger.kernel.org): [ 5.845598@3] a02ff2e02bee64e9955dbfd8811874c3f3880f58 cx231xx: Fix TBS MAC reading. [ 5.854411@3] aml: Unknown symbol get_stream_buffer (err 0) [ 5.854549@3] aml: Unknown symbol tsdemux_set_ops (err 0) [ 5.868061@3] Linux video capture interface: v2.00 [ 5.868071@3] WARNING: You are using an experimental version of the media stack. [ 5.868071@3] As the driver is backported to an older kernel, it doesn't offer [ 5.868071@3] enough quality for its usage in production. [ 5.868071@3] Use it with care. [ 5.868071@3] Latest git patches (needed if you report a bug to linux-media@vger.kernel.org): [ 5.868071@3] a02ff2e02bee64e9955dbfd8811874c3f3880f58 cx231xx: Fix TBS MAC reading. [ 5.906787@3] amlvid:err: amlvideo_init called [ 5.906796@3] amlvid:err: amlvideo_create_instance called [ 5.906802@3] amlvid:err: v4l2_dev.name=:amlvideo-000 [ 5.906978@0] amlvideo-000: V4L2 device registered as video10 [ 5.943648@3] mali-utgard d00c0000.mali: set min pp to default 1 [ 5.943660@3] mali-utgard d00c0000.mali: set min clk default to 0 [ 5.943746@3] mali-utgard d00c0000.mali: max clk set 4 [ 5.943751@3] mali-utgard d00c0000.mali: turbo clk set to 5 [ 5.945521@1] gpu cooling register okay with err=0 [ 5.945629@1] gpu core cooling register okay with err=0 [ 5.945899@1] Mali: Mali device driver loaded [ 5.955904@1] Triggered SDIO WiFi power on and bus rescan. [ 5.955917@1] (NULL device *): [extern_wifi_set_enable] WIFI Disable! 0 [ 6.014514@0] scsi 0:0:0:0: Direct-Access ASMedia AS2115 0 PQ: 0 ANSI: 6 [ 6.015611@1] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB) [ 6.016222@1] sd 0:0:0:0: [sda] Write Protect is off [ 6.016229@1] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 [ 6.016845@1] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 6.021096@0] sda: sda1 < sda5 > [ 6.023741@3] sd 0:0:0:0: [sda] Attached SCSI disk [ 6.263287@1] (NULL device *): [extern_wifi_set_enable] WIFI Enable! 0 [ 6.595877@2] sdio: new high speed SDIO card at address 0001 [ 6.595888@1] sdio: clock 50000000, 4-bit-bus-width [ 6.595888@1] [ 6.596201@1] [sdio_reinit] finish [ 6.693773@3] ------------[ cut here ]------------ [ 6.693803@3] WARNING: CPU: 3 PID: 2469 at /home/afl1/LibreELEC.tv/build.LibreELEC-S905.arm-8.0-devel/media_build-2017-01-22/v4l/v4l2-ioctl.c:999 v4l_querycap+0x98/0xd8 [videodev]() [ 6.693808@3] Bad caps for driver amlvideo, 5200001 0 [ 6.693811@3] Modules linked in: wifi_dummy mali(O) amlvideodri(O) videobuf_res(O) videobuf_core(O) videodev(O) dvb_core(O) media(O) fbcon bitblit softcursor font dwc_otg aml_nftl_dev(P) [ 6.693836@3] CPU: 3 PID: 2469 Comm: v4l_id Tainted: P O 3.14.29 #1 [ 6.693840@3] Call trace: [ 6.693850@3] [<ffffffc001087a58>] dump_backtrace+0x0/0x128 [ 6.693856@3] [<ffffffc001087ba0>] show_stack+0x20/0x30 [ 6.693870@3] [<ffffffc0017b1758>] dump_stack+0x78/0x94 [ 6.693878@3] [<ffffffc0010943e8>] warn_slowpath_common+0x90/0xc0 [ 6.693884@3] [<ffffffc001094478>] warn_slowpath_fmt+0x60/0x78 [ 6.693892@3] [<ffffffbffc0c78d4>] v4l_querycap+0x94/0xd8 [videodev] [ 6.693900@3] [<ffffffbffc0c9540>] __video_do_ioctl+0x248/0x2b8 [videodev] [ 6.693908@3] [<ffffffbffc0c9164>] video_usercopy+0x2b4/0x3f8 [videodev] [ 6.693916@3] [<ffffffbffc0c92e0>] video_ioctl2+0x38/0x50 [videodev] [ 6.693923@3] [<ffffffbffc0c3934>] v4l2_ioctl+0x11c/0x128 [videodev] [ 6.693933@3] [<ffffffbffc0d7f7c>] do_video_ioctl+0x15fc/0x1b80 [videodev] [ 6.693942@3] [<ffffffbffc0d85a0>] v4l2_compat_ioctl32+0xa0/0xa8 [videodev] [ 6.693949@3] [<ffffffc0011efc74>] compat_sys_ioctl+0xa4/0x1570 [ 6.693953@3] ---[ end trace f966509ab66e15f2 ]---
afl1 as usual, thanks for the update.
this sentence still relevant?
- Latest addon service Tvheadend42 is broken. Install fixed version service.tvheadend42-8.1.109.zip and disable auto-update. -
