No WiFi at MXQ PRO 4K 5G
  • At first glance, it works well. :thumbup:
    Did the driver load itself at boot, or did you start it manually with modprobe?
    In the meantime, I backported the persistent journal option to 9.2.8.10, so you can now send me a full system log.
    You can turn this on under Settings -> LibreELEC Settings -> System -> Logging.
    This setting requires a reboot, after that please send a link generated by journalctl | paste. Thanks.
  • someoneelse
    The "new" version (2022) S805-based MXQ box has also arrived for me, and quite a lot points to an inconsistent design:
    • The control of the blue LED (GPIOAO_13) is not handled by uboot, so a kernel patch is needed. Although the absence of a blue LED light when the box is turned on is rather an advantage.
    • The remote GPIO pin is the same (GPIOAO_7), but something different happens during shutdown. When tested on UART, it seems that the device stays on even when turned off under Android, and simply restarts by pressing the button on the remote control. This is not exactly the best solution and indicates a lack of another uboot feature.
    • The clock signal of the SDIO bus is limited from 50 MHz to 37.5 MHz. This may also be related your SD card R/W errors, IDK.
    • The MAC address of the Ethernet is not burned into the efuse, so even under Android it gets a different address during every boot. This is quite annoying.
    I originally planned a separate build for this device, but unfortunately it makes no sense. It would make more sense to compile a bootloader without the above issues. :(
    PS: Regardless, the RTL8723AS wireless chip works perfectly, and it has already been included in the stable version 9.2.8.10. So now you can safely turn on the automatic update again.
  • Regardless, the RTL8723AS wireless chip works perfectly, and it has already been included in the stable version 9.2.8.10. So now you can safely turn on the automatic update again.
    Thanks. Really works perfectly.
    P.S. HDMI-CEC also doesn't work. Nothing can be done about it? :) The biggest inconvenience when using a TV box is to replug the power supply every time to turn it on.
  • Thanks. Really works perfectly.
    I made a dump from the eMMC, and after a short analysis I found out who could be the author of this ROM (M8-20221108).
    I will try to contact him, and if he replies, maybe we can move forward from this point. ;)
    Edit:
    In the meantime, it seems that I managed to burn in the MAC address, which is on the label at the bottom of the box.
    ^ However, this should have been done by the distributor, not the end user... :P
  • Unfortunately, the Android ROM developer ( willie.xu ) didn't respond to my numerous inquiries, so I might end up trying to compile my own uboot for this box, to fixing these errors, if that's possible. (I haven't done this before, so it might not work.)
    But CEC will probably never work because it doesn't seem to even be physically connected.
    At least I have a small sense of success that I was able to carve out a hole for the UART socket at the bottom of the box:
    So don't have to leave this piece of garbage all the time disassembled... 8o
  • (M8)Baby steps...
    Commits · dtechsrv/u-boot
    UBoot for AML CPUs. Contribute to dtechsrv/u-boot development by creating an account on GitHub.
    github.com
    But the KMQN10006B-B318 chip on the PCB, which is an eMMC+LPDDR2 RAM hybrid IC, is pretty insane stuff without any documentation to be found. I'm done with the memory timings, but the system won't start at the moment. (It's booted, but there's still work to be done.)
  • Hi, thanks for all your work, I have your exact same tv box, rk3228 and same wifi module. I am using ilmich's libreelec. How would I go about compiling your driver in order to include it?
    GitHub - dtechsrv/android_hardware_wifi_realtek_drivers_8723as
    Contribute to dtechsrv/android_hardware_wifi_realtek_drivers_8723as development by creating an account on GitHub.
    github.com
    I git clone it and use make, but apparently I f up. If it's much more complex like this, i'll just use it without internet, but perhaps there was an easy way. cheers!
    make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -C ../../../../../../common M=/home/USER/android_hardware_wifi_realtek_drivers_8723as/rtl8723AS  modules              make[1]: *** ../../../../../../common: File or directory does not exist.  Stop.        make: *** [Makefile:843: modules] Error 2
  • I git clone it and use make, but apparently I f up. If it's much more complex like this, i'll just use it without internet, but perhaps there was an easy way. cheers!
    Compiling a kernel module is a bit more complicated than running a simple make.
    The package created for the build of the module used under LE-AML 9.2 can be found here:
    LibreELEC-AML/packages/amlogic/linux-drivers/RTL8723AS-aml/package.mk at master · dtechsrv/LibreELEC-AML
    'Just enough OS' for Kodi for some Amlogic TV boxes - dtechsrv/LibreELEC-AML
    github.com
    However, ilmich uses mainline kernel (6.x) in his builds where this module is probably no longer usable.
  • I can try. The Realtek drivers are very similar, so I should be able to make it work with the new kernels, too.
    Could you please try?
    I got a TV box with both RTL8723AS and RK3228. Your build ran great, although I couldn't make the wi-fi work.
    I am open to share any details to help you add support for this chip - or, at the very least, help me with this issue.
  • Hello willie.xu,
    I am seeking your assistance in recovering a bricked MXQ Pro 4K 5G Android TV box. I found your name through the LibreELEC investigation of the Android firmware build M8-20221108.
    Device identification
    • Retail model: MXQ Pro 4K 5G
    • SoC: Amlogic S805 (Meson8B)
    • CPU: Quad-core ARM Cortex-A5, ARMv7 32-bit
    • Platform identifier: m201C
    • RAM/storage: Reported 2 GB RAM and 16 GB internal storage
    • Original Android: Android 5.1, API 22
    • Original firmware build: M8-20221108
    • Wi-Fi: Realtek RTL8189ES
    • Reported memory/eMCP marking from the related hardware investigation: KMQN10006B-B318
    • Related PCB marking reported in that investigation: MXQ_221805_v1.1 (my individual board revision is not yet independently confirmed)
    Current condition
    The box is currently bricked and no longer boots into Android. I previously used LibreELEC 9.2.8.20 with Kodi 18.9. I am trying to restore the original Android factory software.
    Could you please provide:
    1. The original full factory firmware image compatible with this hardware.
    2. The corresponding Amlogic USB Burning Tool recovery package or instructions.
    3. The matching bootloader and partition layout, if these are separate from the main image.
    4. Confirmation of the PCB revision and memory configuration supported by the image.
    I do not want to flash firmware intended for a different MXQ variant. I can supply PCB photographs and additional chip markings for confirmation.
    If you no longer maintain this firmware, could you please identify the original manufacturer or another source for the correct factory image?
    Thank you for your time and assistance.
  • Hello willie.xu
    I hope you realize that you’ve messaged a user who hasn’t logged into the forum since 2019 and has never posted anything in this thread. As I mentioned, he didn’t respond, even though I tried to reach him via PM and email.
    Unfortunately, it’s clear from your post that it was cobbled together using an AI, and it contains completely incorrect information. Without identifying the exact motherboard, no one will recommend a suitable ROM, that's almost guaranteed.
