Thoradia Add-ons
  • The request to rTorrent has timed out.
    how can i change port i have two files on /storage/.kodi/userdata/addon_data/service.rtorrent
    rtorrent.rc
    rtorrent.rc.sample
    Settings are in rtorrent.rc
    Keep it legal and carry on
  • I am adding aria2 as a service.
    The service starts if /storage/.kodi/userdata/addon_data/service.aria2/aria2.conf exists.
    To enable aria2 rpc: create aria2.conf and restart the service, eg
    1. nano /storage/.kodi/userdata/addon_data/service.aria2/aria2.conf
    2. systemctl restart service.aria2
    To disable aria2 rpc: delete aria2.conf and restart the service, eg
    1. rm /storage/.kodi/userdata/addon_data/service.aria2/aria2.conf
  • add-on repository failed to install on Odroid C2
    09:55:11.790 T:3629437840 ERROR: EXCEPTION: Unknown addon id 'repository.libreelec.tv'.
    09:55:11.791 T:3629437840 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
    - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
    Error Type: <type 'exceptions.RuntimeError'>
    Error Contents: Unknown addon id 'repository.libreelec.tv'.
    Traceback (most recent call last):
    File "/storage/.kodi/addons/service.thoradia/default.py", line 27, in <module>
    release = getTag(getTree(getXML('repository.libreelec.tv')), 'datadir').text.strip('/').split('/')[-3:]
    File "/storage/.kodi/addons/service.thoradia/default.py", line 18, in getXML
    return os.path.join(xbmcaddon.Addon(*id).getAddonInfo('path'), 'addon.xml')
    RuntimeError: Unknown addon id 'repository.libreelec.tv'.
    -->End of Python script error report<--
  • Thoradia Add-ons installs on LibreELEC, which ships repository.libreelec.tv.
    Your system does not appear to provide repository.libreelec.tv.
    Which release of LibreELEC is installed?
    Specify ARCH/DEVICE/PROJECT/VERSION.
  • Can you check if LibreELEC ships the LibreELEC Add-ons repository?
    If not ask GDPR-1 if this is intended.
    If that's my community build then there is no LE repo. I've forked and renamed the repo in my builds but those are basically the same addons.
  • Alister
    Try these commands:
    1. cp -r /usr/share/kodi/addons/repository.rbrepo /storage/.kodi/addons/repository.libreelec.tv
    2. systemctl restart kodi
    If that does not work, install the add-ons individually from zip file.
    This is a dirty hack, though, and I will update Thoradia to take Raybuntu's distribution into account.
    Edited once, last by thoradia ().
  • i have manually installed service.rtorrent-8.2.5.zip, service.rutorrent-8.2.6.zip
    somehow has a problem
    [11.11.2017 12:41:41] WebUI started.
    [11.11.2017 12:41:42] Bad response from server: (0 [error,getplugins]) [11.11.2017 12:41:51] JS error: [webui.js : 762] TypeError: this.systemInfo is undefined
    Alister
    You have installed 8.2 add-ons on a 9.0 LibreELEC: this will likely not work.
    I have updated Thoradia to support Raybuntu's distribution.
    Re-install from bootstrap and report whether or noi it works.
