So seems like there's a daily quota for addon installs, and it's fairly low.
Yep, that's the current workaround. Sorry.
Time displays correctly, and on router too, can connect to Libreelec repository but not kodi repository
I have tried to find other threads explaining why I can't connect to kodi repository, but beyond checking the time is accurate I don't see why I shouldn't be able to connect normally. No problem connecting to libreelec repo at all
problem persists:
I can´t even install NextPVR Client which just fails to install
any solutions?
Update:
I downloaded (one of the dependencies)
and tried to install it directly as zip file on libreelec - installation fails
dunno, how to move on - any suggestions?
I am seeing the same - xxx.xxx.106.110 - trying to download the tvheadend add-on.
Hi,
i made a fresh install of the productive version for raspberry pi 4. The complete addon-subdomain seems to be not available (tested from pc).
In the logfile I get:
Quote2023-02-20 07:34:05.214 T:1171 ERROR <general>: CFileCache::Open - <https://addons.libreelec.tv/10.0.0/ARMv8/a…s.xml.gz.sha256> failed to open
2023-02-20 07:34:05.214 T:1171 ERROR <general>: CRepository: failed read 'https://addons.libreelec.tv/10.0.0/ARMv8/a…s.xml.gz.sha256'
2023-02-20 07:34:05.660 T:1042 WARNING <general>: CGUIMediaWindow::OnMessage - updating in progress
ipv4 is x.x.248.102
ipv6 ends with fe26:b46c/64
Hope this helps.
In your post I read that you are trying to install an android addon, this will never work with LE.
well, thats true - do you know where I can find a proper inputstream.aptive for libreelec on Pi4?
The same issue
x.x.156.102
2023-02-20 20:25:21.550 T:876 error <general>: CCurlFile::Open - <https://addons.libreelec.tv/10.80.12/ARMv8/arm/addons.xml.gz.sha256> Failed with code 0:
2023-02-20 20:25:21.550 T:876 error <general>: CRepository: failed read 'https://addons.libreelec.tv/10.80.12/ARMv8/arm/addons.xml.gz.sha256'
2023-02-20 20:25:22.296 T:769 warning <general>: CGUIMediaWindow::OnMessage - updating in progress
2023-02-20 20:25:22.410 T:875 error <general>: GetDirectory - Error getting addons://repository.libreelec.tv/
2023-02-20 20:25:22.443 T:769 error <general>: CGUIMediaWindow::GetDirectory(addons://repository.libreelec.tv/) failed
From xxx.xxx.138.49 on LibreELEC release: RPi2.arm-9.2.8 I can't install the network tools addon:
2023-02-20 09:35:07.912 T:1936929856 DEBUG: CAddonInstaller: installing 'virtual.network-tools' version '9.2.0.104' from repository 'repository.libreelec.tv'
2023-02-20 09:35:08.038 T:1807721344 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for https://addons.libreelec.tv/9.2.0/RPi2/arm/virtual.network-tools/virtual.network-tools-9.2.0.104.zip
2023-02-20 09:35:08.039 T:1807721344 DEBUG: CurlFile::Open(0x70e10f80) https://addons.libreelec.tv/9.2.0/RPi2/arm/virtual.network-tools/virtual.network-tools-9.2.0.104.zip
2023-02-20 09:35:08.155 T:1807721344 ERROR: CCurlFile::FillBuffer - Failed: Couldn't connect to server(7)
2023-02-20 09:35:08.155 T:1807721344 ERROR: CCurlFile::Open failed with code 0 for https://addons.libreelec.tv/9.2.0/RPi2/arm/virtual.network-tools/virtual.network-tools-9.2.0.104.zip:
2023-02-20 09:35:08.156 T:1807721344 ERROR: CAddonInstallJob[virtual.network-tools]: failed to download special://home/addons/packages/virtual.network-tools-9.2.0.104.zip
2023-02-20 09:35:08.179 T:1936929856 DEBUG: ------ Window Init (DialogNotification.xml) ------
2023-02-20 09:35:08.293 T:1512956800 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for https://addons.libreelec.tv/9.2.0/RPi2/arm/virtual.network-tools/resources/icon.png
2023-02-20 09:35:08.293 T:1512956800 DEBUG: GetImageHash - unable to stat url https://addons.libreelec.tv/9.2.0/RPi2/arm/virtual.network-tools/resources/icon.png
2023-02-20 09:35:08.344 T:1936929856 DEBUG: CGUIMediaWindow::GetDirectory (addons://repository.libreelec.tv/xbmc.addon.executable)
2023-02-20 09:35:08.345 T:1936929856 DEBUG: ParentPath = [addons://repository.libreelec.tv/xbmc.addon.executable]
Display More
Networking is working fine otherwise on the rpi2.
Having problems loading ANY add-ons from https://addons.libreelec.tv/10.80.12/ARMv8/arm... Worked fine just a couple days ago. Here are typical kodi.log messages...
2023-02-20 10:42:37.594 T:1136 error <general>: CCurlFile::CReadState::FillBuffer - (0xd8a7a3c0) Failed: Couldn't connect to server(7)
2023-02-20 10:42:37.594 T:1136 error <general>: CCurlFile::Open - <https://addons.libreelec.tv/10.80.12/ARMv8…ro-20.2.2.1.zip> Failed with code 0:
2023-02-20 10:42:37.594 T:1136 error <general>: CAddonInstallJob[game.libretro]: failed to download special://home/addons/packages/game.libretro-20.2.2.1.zip
2023-02-20 10:42:37.386 T:1136 error <general>: CCurlFile::Stat - <https://addons.libreelec.tv/10.80.12/ARMv8…ro-20.2.2.1.zip> Failed: Couldn't connect to server(7)
2023-02-20 10:42:35.794 T:1132 error <general>: CCurlFile::Stat - <https://addons.libreelec.tv/10.80.12/ARMv8…bretro/icon.png> Failed: Couldn't connect to server(7)
2023-02-20 10:42:34.091 T:1136 error <general>: CCurlFile::Stat - <https://addons.libreelec.tv/10.80.12/ARMv8…bretro/icon.png> Failed: Couldn't connect to server(7)
2023-02-20 10:42:26.184 T:1135 error <general>: CCurlFile::Stat - <https://addons.libreelec.tv/10.80.12/ARMv8…s.sftp/icon.png> Failed: Couldn't connect to server(7)
2023-02-20 10:42:21.773 T:1136 error <general>: CCurlFile::Stat - <https://addons.libreelec.tv/10.80.12/ARMv8…s.sftp/icon.png> Failed: Couldn't connect to server(7)
2023-02-20 10:42:13.815 T:1134 error <general>: CCurlFile::Stat - <https://addons.libreelec.tv/10.80.12/ARMv8…ources/icon.png> Failed: Couldn't connect to server(7)
2023-02-20 10:39:04.836 T:1000 error <general>: CCurlFile::Open - <https://addons.libreelec.tv/10.80.12/ARMv8…s.xml.gz.sha256> Failed with code 0:
2023-02-20 10:39:04.836 T:1000 error <general>: CRepository: failed read 'https://addons.libreelec.tv/10.80.12/ARMv8…s.xml.gz.sha256'
Tried a lot of different things including... the latest nightly LibreELEC build as well as the latest LibreELEC-RR (fork) build, a couple different Raspberry Pis, a PC, and changing to a different IP address.
Any ideas?
CvH
IP: x.x.220.19
2023-02-20 20:13:20.692 T:846 info <general>: Loading skin file: AddonBrowser.xml, load type: KEEP_IN_MEMORY
2023-02-20 20:13:25.112 T:916 error <general>: CCurlFile::CReadState::FillBuffer - (0x6cf8cbe0) Failed: Couldn't connect to server(7)
2023-02-20 20:13:25.113 T:916 error <general>: CCurlFile::Open - <https://addons.libreelec.tv/10.80.12/ARMv7/arm/addons.xml.gz.sha256> Failed with code 0:
2023-02-20 20:13:25.113 T:916 error <general>: CRepository: failed read 'https://addons.libreelec.tv/10.80.12/ARMv7/arm/addons.xml.gz.sha256'
2023-02-20 20:13:25.161 T:846 info <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2023-02-20 20:13:25.674 T:846 warning <general>: CGUIMediaWindow::OnMessage - updating in progress
# curl -ILv https://addons.libreelec.tv/10.80.12/ARMv7/arm/addons.xml.gz.sha256
* Trying 134.209.250.70:443...
* connect to 134.209.250.70 port 443 failed: Connection refused
* Failed to connect to addons.libreelec.tv port 443 after 22 ms: Couldn't connect to server
* Closing connection 0
curl: (7) Failed to connect to addons.libreelec.tv port 443 after 22 ms: Couldn't connect to server
# curl -ILv https://libreelec.tv
* Trying 185.199.111.153:443...
* Connected to libreelec.tv (185.199.111.153) port 443 (#0)
* ALPN: offers h2
* ALPN: offers http/1.1
* CAfile: /run/libreelec/cacert.pem
* CApath: none
* TLSv1.0 (OUT), TLS header, Certificate Status (22):
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Suppl... data (23):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.2 (OUT), TLS header, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS header, Suppl... data (23):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* ALPN: server accepted h2
* Server certificate:
* subject: CN=libreelec.tv
* start date: Feb 4 04:09:56 2023 GMT
* expire date: May 5 04:09:55 2023 GMT
* subjectAltName: host "libreelec.tv" matched cert's "libreelec.tv"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* Using HTTP2, server supports multiplexing
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
* h2h3 [:method: HEAD]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: libreelec.tv]
* h2h3 [user-agent: curl/7.86.0]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x511ec8)
> HEAD / HTTP/2
> Host: libreelec.tv
> accept: */*
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
* old SSL session ID is stale, removing
< HTTP/2 200
HTTP/2 200
< server: GitHub.com
server: GitHub.com
< content-type: text/html; charset=utf-8
< last-modified: Sat, 18 Feb 2023 10:47:09 GMT
< access-control-allow-origin: *
< etag: "63f0acad-27e0"
< expires: Mon, 20 Feb 2023 06:56:06 GMT
< cache-control: max-age=600
< x-proxy-cache: MISS
x-proxy-cache: MISS
< x-github-request-id: AA6E:8B47:16273C2:1717872:63F3172E
< accept-ranges: bytes
< date: Mon, 20 Feb 2023 19:29:14 GMT
< via: 1.1 varnish
via: 1.1 varnish
< age: 0
< x-served-by: cache-vie6377-VIE
< x-cache: HIT
x-cache: HIT
< x-cache-hits: 1
x-cache-hits: 1
< x-timer: S1676921354.256148,VS0,VE102
< vary: Accept-Encoding
< x-fastly-request-id: 1ac2f9150adcc88ccf0e5c70aa903cefbbe149f5
< content-length: 10208
* Connection #0 to host libreelec.tv left intact
Display More
2023-02-20 20:31:10.205 T:936 error <general>: GetDirectory - Error getting addons://repository.libreelec.tv/
2023-02-20 20:31:10.237 T:846 error <general>: CGUIMediaWindow::GetDirectory(addons://repository.libreelec.tv/) failed
# dig repository.libreelec.tv @8.8.8.8
; <<>> DiG 9.16.37-Debian <<>> repository.libreelec.tv @8.8.8.8
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 7923
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;repository.libreelec.tv. IN A
;; AUTHORITY SECTION:
libreelec.tv. 1800 IN SOA anna.ns.cloudflare.com. dns.cloudflare.com. 2302204955 10000 2400 604800 3600
;; Query time: 20 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Mon Feb 20 20:34:16 CET 2023
;; MSG SIZE rcvd: 114
# dig repository.libreelec.tv @anna.ns.cloudflare.com
; <<>> DiG 9.16.37-Debian <<>> repository.libreelec.tv @anna.ns.cloudflare.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 9297
;; flags: qr aa rd; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; WARNING: recursion requested but not available
; EDNS: version: 0, flags:; udp: 1232
libreelec.tv. 3600 IN SOA anna.ns.cloudflare.com. dns.cloudflare.com. 2302204955 10000 2400 604800 3600
;; Query time: 16 msec
;; SERVER: 173.245.58.102#53(173.245.58.102)
;; WHEN: Mon Feb 20 20:34:27 CET 2023
# dig repository.libreelec.tv @hans.ns.cloudflare.com
; <<>> DiG 9.16.37-Debian <<>> repository.libreelec.tv @hans.ns.cloudflare.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 37616
;; Query time: 8 msec
;; SERVER: 173.245.59.175#53(173.245.59.175)
;; WHEN: Mon Feb 20 20:34:32 CET 2023
Display More
Btw: "The message contains contained censored words: suppl*mental (15×)."
Experiencing the same, haven't downloaded anything from the repo before.
2023-02-20 13:47:12.988 T:984 DEBUG <general>: CAddonInstaller: installing 'virtual.network-tools' version '10.0.0.120' from repository 'repository.libreelec.tv'
2023-02-20 13:47:13.088 T:984 DEBUG <general>: CGLContextEGL::SwapBuffers: sync check blocking
2023-02-20 13:47:13.120 T:984 DEBUG <general>: CGLContextEGL::SwapBuffers: sync sleep: 31425
2023-02-20 13:47:13.183 T:1164 ERROR <general>: CCurlFile::Stat - Failed: Couldn't connect to server(7) for https://addons.libreelec.tv/10.0.0/Generic/x86_64/virtual.network-tools/virtual.network-tools-10.0.0.120.zip
2023-02-20 13:47:13.183 T:1164 DEBUG <general>: CurlFile::Open(0x7f43003bbd20) https://addons.libreelec.tv/10.0.0/Generic/x86_64/virtual.network-tools/virtual.network-tools-10.0.0.120.zip
2023-02-20 13:47:13.357 T:1164 ERROR <general>: CCurlFile::FillBuffer - Failed: Couldn't connect to server(7)
2023-02-20 13:47:13.357 T:1164 ERROR <general>: CCurlFile::Open failed with code 0 for https://addons.libreelec.tv/10.0.0/Generic/x86_64/virtual.network-tools/virtual.network-tools-10.0.0.120.zip:
Hi,
I will reinstall my Raspberry Pi4 with Libreelec and some Addons.
The Repo are not working
IP:
XX.XXX.12.181
Please let me know if is possible to install some addons.
Thanks in advance
https://addons.libreelec.tv/ appears to be down.
libreelec:~ # curl -v --fail-with-body https://addons.libreelec.tv/
* Connected to addons.libreelec.tv (134.209.250.70) port 443 (#0)
* ALPN: offers h2
* CApath: none
* TLSv1.0 (OUT), TLS header, Unknown (21):
* TLSv1.3 (OUT), TLS alert, decode error (562):
* error:0A000126:SSL routines::unexpected eof while reading
curl: (35) error:0A000126:SSL routines::unexpected eof while reading
Display More
Thinking it might just be me, I checked further. It isn't:
Addons.libreelec.tv is DOWN
It is not just you. The server is not responding...
Here's hoping it's just a simple config issue somewhere.
its fixed for now, I adjusted the config again to prevent it, maybe its works now better
Many Thanks for your work.....
Works for me, thank you.
Is this still an issue?
I've upgraded from 10.0.4 to 11.0.0 and post boot it seems none of my addons are able to update. Hence I am unable to get the PVR menu to appear in addons so that I can update my TVHeadeand htsp client to one that is compatible with 11.0.0
Kodi.log shows this snippet:
error <general>: CCurlFile::Open - <https://addons.libreelec.tv/11.0.0/ARMv8/a…s.xml.gz.sha256> Failed with code 429:
which seems to indicate I have exceeded my quota? (I upgraded directly via ssh and wget)
My IP is x.x.229.22
