[x86-64] HDR Playback
smp -
January 22, 2022 at 3:28 PM -
Thread is Resolved
BT.2020 issue should now be fixed in the nnightl
if I change I see dark hdr again.
Only hdr ok with your compilation.
What image did you try?
LibreELEC-Generic.x86_64-12.0-nightly-20230514-e7ccb95.img.gz
Running nightly-20230514-e7ccb95 (Generic.x86_64) on an Intel n100 device I'm able to activate HDR correctly, connected directly to an LG C1. I've abandoned running video through my AVR as it had a lot of trouble 'locking on' to video mode changes / audio format changes (as well as intel's high resolution audio dropouts); luckily my device has dual HDMI outs.
Thought I'd report that the 'last' nightly of v11 (LibreELEC-Generic.x86_64-11.0-nightly-20230519-c3ca265.img.gz) does not have the bt.2020 fix (not sure if this is intentional); Don't want to to regress it forward to the v12 builds.
Hi
I've got mixed results with 4k and HDR with Generic.x86_64-11.0.1
With "Adjust refresh" on, I can get 4k video in SDR, without HDR
With "Adjust refresh" off, I can get 1080p video with HDR at 60Hz (i.e. the refresh rate configured for kodi menu).
I've tried nightly build but the video output is corrupted: I get green colored band when the displayed image changes (i.e. changes in menu screen or when playing a video).
Is there any way to fix this ?
All the best
Thought I'd report in that using a Beelink n100-based mini PC and the latest build posted in this thread I am getting proper HDR10/bt.2020 triggering on my setup: Pioneer AVR to LG C1 TV. It's looking great!
I was thinking about getting a Beelink N100 myself due to the working BT.2020 triggering... but this HD audio bit got me worried. Isn't HD audio passthu working?
The only way I've gotten HD audio (TrueHD/DTS-HD/MA) to reliably stream without dropouts is to separate video & audio signals; This means you cannot have the AVR connected to your display ( otherwise libreelc will just 'clone' the signal out, causing the same issue) , and have to utilize both HDMI outs (one going directly to your display, the other going directly to your audio processor).
Thanks for replying. Even though your issue isn't too encouraging I guess I'll take a shot at the DDR5 version of the box.
I was also considering the alternatives (even Amlogic boxes) but I guess nothing beats the flexibility, convenience and power of a minipc. If everything goes wrong I can always use it as a router, heh.
Thinking about your issue... can't you use some kernel boot params in syslinux.cfg to force video output separated from audio (and avoid cloning) and thus maintain de video connected to the AVR?
I didn't test it on my current setup (I don't have 2 HDMIs) so I really don't know if it would work. Here is where I got the idea:
ThreadIs there a key combination to clone/change the screen?
So I have this Samsung NP300E5A laptop which doesn't have a lid, when I open the system (fresh install) Kodi opens up on the integrated screen which is no longer available and the monitor I'm willing to use only shows the logo or a gray background. I need help for getting that screen on my monitor, thanks!metinMarch 26, 2023 at 5:00 PM -
On my side, audio pass-thru is working with DTS-HD, MA and TruHD and HDR, albeit at 1080p...
any news for support "HLG" for DVB Addon?
i have issue when play HLG from DVB
Updated build with Kodi 20.1
LibreELEC-Generic.x86_64-11.0-devel-20230312065957-84d83d1.img.gz
The image is working rather nicely with HDR/BT.2020 and pvr channels switching fixes, thank you!
Can you update it to current LE 11.0.3? Or maybe publish the patches involved so we can build it ourselves. Thanks!
smp that does not build on top of 11.0.3 (in my community build where i do not tocuh kodi anywhere)
i get http://ix.io/4Bfb and then try to find out if i missed something.
Found where the patch is comming from but have no idea if i need something else from here
https://github.com/xbmc/xbmc/comp…-no-ffmpeg-bump
Any pointers?I do play around for a while with the thought to build a extra "device" in my community build with the needed patches that are in this thread here. Now as i get it presented on a table (thank you) i did try, but no luck.
Any pointers?
Sorry, it was the wrong patch. It should compile with this one:
https://github.com/xbmc/xbmc/commit/c51dc4b07dbcbbe49ae0cf24b4fba2079ca63425.patch
Thanks this one did compile.
But for me it is not working except black screen, but that is new before the patch it stuck without getting a black screen.
Hardware B360M-ITX/ac, i3-8100, Denon X6700H, LG55E6D.Media my own 4k discs remux with makemkv and lots of samples.
That is not really a problem for me because i use a Vero 4k+ since it was released for HDR and now for testing a RPi4 too. But one can hope to just use one fast x86_64 device for all media.
If somebody is interessted you find my LE 11.0.3 comunity build + lvm and encryption + the 2 patches from here under http://sky42.libreelec.tv/release/11.0/G…Generic-BT2020/ .
The way back without forced update needs 1st a update to my Generic 11.0.3-#230723 and then back to official LE.
The commit with all the changes is https://github.com/sky42src/LibreELEC.tv/commit/fe9d270 -
