I try to setup LE 10.0.1 generic on a NUC7i3, and i face these 2 problems.
1. HDMI gives me only up to 30hz support on 4K, (the HDMI on NUC7i3 supports up to 60hz) and HDMI-CEC is not working
2. SSH and TigerVNC work fine when the connection is on DHCP (wifi connection), but both throw a "connection refused" when i set the connection to static.
Going back and forth from dhcp to static to troubleshoot, most of the times causes KODI to crash and restart.
The settings i use are correct, not the first time i do this.
Something i miss?
