Hello Everyone !
I've installed Libreelec 9.2.7 on my raspberry pi 4.
My audio is a small usb audio device. The sound works great in kodi (actually Libreelec detect the usb audio card and automatically used it in kodi whish is realllly great)
I've configured MPD addon almost flawlessly (I've struggled finding the good mpd.conf file...). I didn't change anything about sound configuration in mpd.conf.
I can connect to the MPD server and see my music library and start playing a song from my MPD client and the song seems to play but I have no sound (sound in kodi is good)
aplay -l output this :
LibreELEC:~ # aplay -l
card 1: Device [USB Audio Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
aplay -L output :
LibreELEC:~ # aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=Device
USB Audio Device, USB Audio
Default Audio Device
sysdefault:CARD=Device
front:CARD=Device,DEV=0
Front speakers
surround21:CARD=Device,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Device,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Device,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Device,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Device,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Device,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Device,DEV=0
IEC958 (S/PDIF) Digital Audio Output
Display More
aplay a musicfile gives this :
LibreELEC:~ # aplay /media/MainDrive/RadioactivSonnerie.mp3
ALSA lib /home/chewitt/LibreELEC.widevine/build.LibreELEC-RPi4.arm-9.2.7/alsa-lib-1.1.9/src/confmisc.c:767:(parse_card) cannot find card '0'
ALSA lib /home/chewitt/LibreELEC.widevine/build.LibreELEC-RPi4.arm-9.2.7/alsa-lib-1.1.9/src/conf.c:4568:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
ALSA lib /home/chewitt/LibreELEC.widevine/build.LibreELEC-RPi4.arm-9.2.7/alsa-lib-1.1.9/src/confmisc.c:392:(snd_func_concat) error evaluating strings
ALSA lib /home/chewitt/LibreELEC.widevine/build.LibreELEC-RPi4.arm-9.2.7/alsa-lib-1.1.9/src/conf.c:4568:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib /home/chewitt/LibreELEC.widevine/build.LibreELEC-RPi4.arm-9.2.7/alsa-lib-1.1.9/src/confmisc.c:1246:(snd_func_refer) error evaluating name
ALSA lib /home/chewitt/LibreELEC.widevine/build.LibreELEC-RPi4.arm-9.2.7/alsa-lib-1.1.9/src/conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib /home/chewitt/LibreELEC.widevine/build.LibreELEC-RPi4.arm-9.2.7/alsa-lib-1.1.9/src/conf.c:5047:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib /home/chewitt/LibreELEC.widevine/build.LibreELEC-RPi4.arm-9.2.7/alsa-lib-1.1.9/src/pcm/pcm.c:2564:(snd_pcm_open_noupdate) Unknown PCM default
aplay: main:828: audio open error: No such file or directory
Sounds weird to have such an error in aplay and, in the same time, having no sound issue in Kodi.
Does anyone has any hint ??
Thank you !
Stan
PS : it worked perfectly in xbian (but xbian crashed one day and I decided to install Libreelec
