Two Questions, is this MXQ-4K-Pro_2G.arm-9.2.8.3.img.gz will work in my box ?, as it says 2G ram where as my box is 1GB Ram, and another do i have to download this gxbb_p200_1G_mxq_pro_4k.dtb, and rename it to .dtb.? Can i extract & use the the .dtb file which is already there in my (LibreELEC-Amlogic.aarch64-MXSPlus-8.0.3-update) given by the supplier of the box.
dtech  -
February 7, 2021 at 2:33 PM  -
Thread is Resolved
- That 2GB in the name is only present because the image was created for this device: MXQ 4K Pro+ (S905X, 2G/16G).
The size of the memory is specified in the DTB, so if you replace it, the name is already irrelevant. - Yes, you can, but since your DTB is from an older build, it is not 100% sure it will work.
Hello everyone. I just now install the 18.9 Leia update in my Amlogic tv box MXIII-G 2 GB/8 GB. I install the LibreELEC-MXIII-Plus.arm-9.2.8.3 file, by puting the tar file in the update folder. Everything seems working fine. I just want to ask is there any way to get a 19.0 matrix update for my tv box?
Since Matrix (Kodi v19) the legacy amlcodec is no longer supported. The old kernel (3.10) is already very outdated anyway, so the only solution is to switch to the mainline kernel. At the moment the state of the vdec is pretty much WiP. However, there is some progress in this area (Meson 8* Lives!), but it seems that Kodi v20 may be the first to run on Meson8* devices.
Thanks for your answer. And another question I have to do. After installing the 9.2.8.3 in my tv box when i reboot the box the libreelec logo at the beginning had disappear. Instead of the libreelec logo I see a very long incomprehensible list of a text for a while and after that the tv box is booting to Kodi. Is there anyway to fix it ?
Okay, this is a new issue... Can I get a photo of that?
It looks like "quiet" is missing from boot params (so you see the earlycon boot content).
I don't understand. What I have to do to fix it ?
The logo should hide the console output, but something is wrong with the resolution at boot time.
But I see the first lines of the LE logo at the bottom of the screen, and the image is also quite distorted.
I need a dmesg and an fw_printenv output shortly after the Kodi is loaded.
Please explain me how to get these outputs ? Sorry but I'm a little silly !
SSH into the box and run the commands "dmesg | paste" and "fw_printenv | paste" then share the URLs generated.
The logo should hide the console output, but something is wrong with the resolution at boot time. But I see the first lines of the LE logo at the bottom of the screen, and the image is also quite distorted.
LibreELEC:~ # dmesg | paste
LibreELEC:~ # fw_printenv | paste
Which version did you update from?
Before I was in 18.6 LibreELEC for MXIII-Plus
(LibreELEC-MXIII_Plus.arm-LE9-Kodi_18.6)
Downloads for : Amlogic MXQ TV Box | AndroidFileHost.com | Download GApps, Roms, Kernels, Themes, Firmware and more. Free file hosting for all Android developers.Download GApps, Roms, Kernels, Themes, Firmware, and more. Free file hosting for all Android developers.androidfilehost.comMy tv box is the MXIII-G 2GB/8GB
LibreELEC-n200-AP6330_2G.arm-9.2.8.2 - some glitches at boot(when you see "linux things" - same with last snapshot but not important).
loki7777 Have you experienced this too?
I mean, did it show up for you instead of the logo?
However, if the onscreen log only appears for a moment and only flashes once before the logo loads, it's completely normal. It doesn't really show up on some TVs, it happens so quickly.
Yes. I have google tv logo(around)5sec, glitches(around 5sec too) after that Kodi logo. But i'm ok with that;)
No logo appears even for a moment.
