system.d Problems mounting NAS
  • I've tried using CIFS and NFS but neither working. Here is the log: http://ix.io/2GnH
    For CIFS to mount onto directory "NAS"
    [Unit]
    Description=cifs mount script
    Requires=network-online.service
    After=network-online.service
    Before=kodi.service
    [Mount]
    What=//192.168.1.14/Volume1
    Where=/storage/nas
    Options=username=admin,password=XXXXXXX.,rw,vers=1.0
    Type=cifs
    [Install]
    WantedBy=multi-user.target
    Enabled using PuTTY "systemctl enable storage-nas.mount"
    ____________________________________
    For NFS (onto a different directory "NSA")
    [Unit]
    Description=nfs mount script onto NSA
    Before=kodi.service
    [Mount]
    Where=/storage/nsa
    Options=
    Type=nfs
    [Install]WantedBy=multi-user.target
    Enabled using PuTTY "systemctl enable storage-nsa.mount"
    I don't really mind which is used. The NAS can only run Samba v1.0 which I guess would make the NFS method preferable?. The NAS is fixed IP address.
    Any help much appreciated.
  • Thanks but it's a ZyXEL NSA325v2. It only supports Samba v1.0 but also NFS.
    With CIFS the error is "permission denied". But I don't understand why when I can see the files on there when I browse for new share under "Windows network (SMB)". However I need to be able to mount the drive.
    (The error with NFS mount is "Invalid Argument")
  • NFS is not SMB, use What=192.168.1.14:/Volume1.
    Thanks, that gave me "Permission Denied" so getting closer.
    I went back into the NAS which said the NFS Share full path for Volume1 is:
    /i-data/e6510fdf/nfs/KodiShare
    So I changed system.d to:
    What=192.168.1.14:/i-data/e6510fdf/nfs/KodiShare
    That gave me a report that said: LibreELEC systemd[1]: Mounted nfs mount script onto NSA (i.e. no errors?)
    I assumed that was ok and that I would be able to access the NAS from /storage/nsa, but there's nothing in there - just 3 dots.
    So I how do I see the files on the NAS? Sorry for the dumb question and thanks for your patience!
  • Three dots? Do you see . and ..? Is this the output of ls -a /storage/nsa?
    Use systemctl status storage-nsa.mount and journalctl -u storage-nsa.mount to see systemd messages. mount is showing all succesfil mounts from system.
    And simple but important: is there anything stored below /i-data/e6510fdf/nfs/KodiShare on the NAS?
  • In case this is helpful..
    Assume you have allowed specified device/IP's on your network NFS access to confirmed folders/files on your NAS? Looking in ZyXEL NSA325v2 manual on page 232 (Within section 11 add packages) it explains how to set-up required access to a user/device on network once you have installed the NFS package on the NAS. NSA325 v2_V4.70 Ed4.pdf
    Edited once, last by MikeKL (December 5, 2020 at 1:54 PM).
  • Thanks everyone, Kodi / System Info / storage shows it is mounted correctly.
    I'll figure out the NAS peculiarities.
    Finally I can start to have some fun with it!
    Cheers
