Official LE11 Test Images for Amlogic (Kodi-20)
CvH -
August 28, 2020 at 11:13 AM -
Closed -
Thread is Resolved
CE or any of its spin-offs like AE
Sorry for the offtopic, but what's AE? (I tried duckduckgo and wikipedia before asking but the keyword is too short to get any meaningful result)
E stands for elec i think to remember theres some alexelec besides coreelec one I never tried, the other I didn't like because of my kernel 3.x allergy
Oh, alexelec, that must be it. It seems interesting, pity that I don't understand russian and using google translate all the time is tiring.
For some tvbox hacking russian would definitely be an asset, I also only know about 3 words of that language :-S
- Official Post
"AlexELEC" is a Ukranian rip-off release. He originally cloned OE, then LE, and now I think CE, re-attributing all the commits/changes to himself and never contributing anything back to any of the codebases - although since his images are rammed full of piracy crapware like Acestream we're kind of okay not having anything to do with him/them.
OK, I won't go there then. I just reluctantly switched to coreelec to see the state of the integrated dvb and I have to say it works (though I think it's because they don't use the upstream kernel but the 4.19 bsp, but then I had to select the media_build dvb drivers instead of the default ones).
- Official Post
DVB is one of the more challenging bits of our codebase. Support for USB and PCI type devices improves significantly in modern kernels as several of the major vendors "got their stuff together" and upstreamed their drivers; and the upstreaming processes ironed out lots of quirky crap code. However boxes with embedded cards like Amlogic devices are still a long way from being supported in mainline so the BSP kernels are still functionally best, but also aren't perfect (and the code is horrible) and the people who championed work on them appear to have stopped work and drifed away, so they aren't improving over time.
Yes, I've been reading your messages about it, but since the main purpose of this box is to watch satellite tv I have no other option than to use the old 9.0.something libreelec (which I did until yesterday) or coreelec. From a quick look at their github it seems they are using the upstream media_build for the dvb drivers (albeit an old version) with almost no patches (just to disable several modules). With libreelec I had to use the built-in drivers, the media_build one didn't work (the reverse is true with coreelec).
I don't know if this helps! they are certainly different things to do. (I don't understand about the same)
Ubuntu 20 with raspberry pi 3 tuner is already a reality.
Using latest linux.
This leaves me confused because it is a usb tuner.
We wanted to know if that possibility exists.
raspberry 3 + ubuntu 20 + tbs5520se
What's your friend box?
I have a mecool k1 pro (availink 6862)
LibreELEC-S905.arm-9.0.2.img.gz
This construction of libreelec 9.0.2 has kodi 18.9.Updated.
Updated dvb drivers: crazycat.
ffmpeg: updated.
It was the best construction to use with satellite for my KI Pro.
All credits goes to, The friend helped with it! dtech
This image and the one I use today is the one that is best in my box.
olivluca You don't need to install the crazycat driver for the tuner!
More when installing it, the crazycat box driver develops the tuner better.
I was wrong, no trace of amlogic frontends in media_build/media_tree. I'll have to study from which repo the overlay is built. Or just sit back, relax, and enjoy tv
chewitt Thanks for the support in your constructions.
I'm having problems with libreelec's initial settings.
Samba + ssh is not being activated.
I noticed that the KI Pro dtb.img is present, among others.
Boot is working perfectly.
LibreELEC-AMLGX.arm-9.80.7-box.img.gz 2020-Dec-05
- Official Post
I haven't touched Samba and SSH. Both work for me
I think SSH needs to be activated and a PW set via the remote control before use?!
have a look in the libreelec settings
As I said the problem is here!
In the initial settings.
When I try to activate SSH, samba deactivates, and both do not.
