Hi all,
Recently purchased a Raspberry Pi 4 and the Argon40 Argon ONE case for it.
Followed the instructions here:
Argon40 Argon ONE Installation Guide for LibreElec Raspberry Pi Portal in Asia
...and I am guessing it all installed fine, as the power button works and I can manually turn the fan on and off by connecting over SSH and using ./argonone-config
However, I cannot figure out how to change the auto fan control temperature and fan speed steps. Default values are apparently:
55 C = 10%
60 C = 55%
65 C = 100%
Problem is, when playing 4K files I could not get it to go over 50, so I can't tell if the auto-fan control is working.
I would like to change it so it comes on at 10% speed at 40 C, at least so I can test that the auto fan speed is doing it's thing.
Can anyone advise how I do this? I realise this is not an LE issue but hoping someone in the community also loves LE and this case and has gotten it working
Cheers!
