I recently moved a libreelec pi2 to a room without UTP. I have sourced a RTL8188 USB wifi dongle, I am no expert but through this forum and links to compatablity lists I think that would have been a save bet (happy to be proved wrong, open to suggestions for worryfree alternatives).
Wifi with this dongle has been far from trouble free. After every reboot the wifi connection is listed as failed. If I then connect it will connect but I never know how long that stays working.
I already changed the network timeout on boot to 30s.
Just tried to move a backup file (400mb) ov er Wifi to my laptop and I never succeeded in downloading the file. I moved it to a room with UTP just to get it done.
Searching here i found the lsusb -v command.
Happy to post logs but am now connected to UTP in order to download them so advice appreciated on what to "do" while logging is on. Assume unplug UTP, try to connect, have it fail a few times and then connect via UTP to get the log?
LibreELEC:~ # lsusb -v
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0bda Realtek Semiconductor Corp.
idProduct 0x8179 RTL8188EUS 802.11n Wireless Network Adapter
bcdDevice 0.00
iManufacturer 1 Realtek
iProduct 2 802.11n NIC
iSerial 3 0092C50682C9
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 39
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0002
(Bus Powered)
Remote Wakeup Enabled
Display More
